Sysprogs forums › Forums › VisualGDB › msbuild.exe a solution on the command line?
- This topic has 7 replies, 2 voices, and was last updated 7 years, 11 months ago by
April 6, 2018 at 18:06 #20636
helpme
ParticipantI’m using visualgdb and vagrant to build a linux project from visual studio. All works fine through the Visual Studio IDE, but when calling msbuild on the command line it has issues finding vagrant.exe. Vagrant.exe is in the PATH and in the Tools->Options->VisualGDB settings. Does visualgdb support building the solution from the command line?
Here is the error:
“C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\MSBuild\15.0\Bin\msbuild.exe” foo.sln /p:Configuration=Release /p:Platform=VisualGDB /m /l:FileLogger,Microsoft.Build.Engine;logfile=foo.txt
3>CommitRemoteBuild:
VisualGDB version 5.4.1.2126
System.Reflection.TargetInvocationException
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Exception: Cannot find vagrant.exe in PATH directories. Please specify its path manually via Tools->Options->VisualGDB
at pw1.e()
at pw1.m(i b, rt a)
at iw.y(String b, String a)
at iw.b.i(String b, String a, g c)
at iw.f(RemoteHostSettings a)
at tu1.f(RemoteHostSettings b, Boolean a)
at di1.o4(SourceTransferAction c, SourceCache a, mg b)
at pn1.b_2(Boolean b, Boolean& a)
at br.j(BuildMode a, g b)
at br.e(BuildMode a)
at w51.e(String b, BuildMode c, i a)
at VisualGDB.MSBuild.BuildHelper.LaunchBuildAction(String action, String settingsFile, String generatedMakefile, String targetPath, String cancelEventName, IBuildCallbacks callbacks, Boolean suppressErrorParsing)
at Sysprogs.build.tasks.shared.LaunchVisualGDB.<>c__DisplayClass21_0.<Execute>b__0()
— End of inner exception stack trace —
at Sysprogs.build.tasks.shared.LaunchVisualGDB.Execute()
—Inner exception—
at pw1.e()
at pw1.m(i b, rt a)
at Sysprogs.build.tasks.shared.LaunchVisualGDB.<>c__DisplayClass21_0.<Execute>b__0()April 7, 2018 at 04:37 #20640support
As the environment variables like PATH are set per-process and are inherited from the parent process, sometimes some unexpected configuration settings interfere with them.
Please double-check the PATH value from the same command-line prompt where you run MSBuild (also ensure it’s the same user account that runs VS, as the manual vagrant location is set per-user).
April 9, 2018 at 18:07 #20650helpme
ParticipantThe PATH in the command prompt contains the vagrant.exe and it works, but when using msbuild, VisualGDB can’t find the vagrant.exe. The user account is the same.
Does msbuild work for you? Even though msbuild fails, I was able to use devenv.com successfully in the same command prompt window. Does VisualGDB require the Visual Studio IDE to load properly?
This worked:
“\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\devenv.com” foo.sln /rebuild “Release|VisualGDB” /Out foo.log
April 10, 2018 at 03:10 #20661support
Yes, we have double-checked it with MSBuild and could not get any error (other than VirtualBox issues from trying to access an elevated instance from a non-elevated command prompt). Please try this build, it will list the exact PATH directories it checks and the explicit vagrant location from the settings: http://sysprogs.com/files/tmp/VisualGDB-5.4.1.2164.msi
Please double-check the output for typos, extra spaces/quotation marks, UAC-related problems, etc.
April 10, 2018 at 20:40 #20667helpme
ParticipantIt is odd that visualgdb works fine when using devenv.com, but fails with msbuild being unable to find vagrant.exe (both programs started from the same command prompt so the permissions are identical).
What msbuild options did you use to get the build to succeed?
Are you using VS2017?
Here is the latest output:
“C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\MSBuild\15.0\Bin\msbuild.exe” foo.sln /p:Configuration=Release /p:Platform=VisualGDB /m /l:FileLogger,Microsoft.Build.Engine;logfile=C:\foo.txt /verbosity:d
Using “LaunchVisualGDB” task from assembly “C:\Program Files (x86)\Sysprogs\VisualGDB\Sysprogs.Build.Tasks.dll”.
Task “LaunchVisualGDB”
VisualGDB version 5.4.1.2164
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Exception: Cannot find vagrant.exe in PATH directories. Please specify its path manually via Tools->Options->VisualGDB. Checked PATH: ; Explicit location: C:\HashiCorp\Vagrant\bin
at uf1.h()
at uf1.b(l a, o02 b)
at xi2.h1(String b, String a)
at xi2.e.i(String b, String a, g c)
at xi2.e1(RemoteHostSettings a)
at pc.d(RemoteHostSettings b, Boolean a)
at g6.q4(SourceTransferAction a, SourceCache b, zd2 c)
at hx1.a_2(Boolean a, Boolean& b)
at ik.j(BuildMode b, f a)
at ik.i(BuildMode a)
at pr1.a(String c, BuildMode a, c b)
—Inner exception—
System.Exception: Cannot find vagrant.exe in PATH directories. Please specify its path manually via Tools->Options->VisualGDB. Checked PATH: ; Explicit location: C:\HashiCorp\Vagrant\binC:\> dir C:\HashiCorp\Vagrant\bin
Directory of C:\HashiCorp\Vagrant\bin
01/29/2018 08:05 PM 2,279,424 vagrant.exeApril 11, 2018 at 00:39 #20672support
Thanks for sharing the error message. It looks like some MSBuild rules might be overriding the PATH variable (enabling verbose msbuild output might help diagnose it) and the explicit location is not working because it specifies the directory name, not the full path of vagrant.exe. You can simply change it to C:\HashiCorp\Vagrant\bin\vagrant.exe and it will work.
April 11, 2018 at 21:36 #20687helpme
ParticipantI previously tried to set the full path in Tools->Options->VisualGDB, but it didn’t work. The key was to restart Visual Studio after changing the path.
I’m using the default msbuild rules and property sheets, so nothing is overridden on purpose and other tools in the %PATH% work fine…just not VisualGDB trying to find vagrant.exe. I have it working now by modifying the options, so thank you.
April 12, 2018 at 05:42 #20688support
Good to know it works. It’s hard to say what part of the build process resets the PATH variable. It did not get reset in our test environment and it could be tricky to track it down, so if the manual location works, we would advise to keep using it.
