Sysprogs forums › Forums › VisualGDB › misplaced make files??
- This topic has 6 replies, 2 voices, and was last updated 7 years, 5 months ago by
April 2, 2019 at 09:48 #24539
Brian Beuken
ParticipantI regulary work from my laptop at home and main PC at work, but recently a strange issue has occured after doing quite a bit of work on my PC then transferring to my laptop(via svn)
I get this error on clean, rebuild and build ONLY on the laptop, the main PC still seems quite happy to build this.
1>VisualGDB: Run “make -f Makefile CONFIG=Debug clean -j4” in directory “/tmp/VisualGDB/c/Users/beuken/Desktop/updatedopengl/Lesson10/Lesson3Again” on pi@192.168.178.23 (SSH)
1>Makefile:23: TestFramework.mak: No such file or directory
1>make: *** No rule to make target ‘TestFramework.mak’. Stop.which relates to line 23 n the make file which is
include $(ADDITIONAL_MAKE_FILES)
TestFramework was a small test project I tried out to see how Visual Studio’s new linux builds compared, but it is no longer in my config, so I’m a bit confused why a VisualGDB project is referencing it, and I can’t find any options anywhere to remove that reference.
Any ideas?
April 2, 2019 at 10:55 #24541Brian Beuken
ParticipantI actually found the TestFramework.mak file on my PC…its empty, created by VisualGDB surprisingly (I must have done a testframework for that too) and I added it to my svn and now the laptop is happy again.. But I would like to remove this dependancy, and just can find where to do that?
April 2, 2019 at 16:58 #24542support
Please use VisualGDB Project Properties -> Unit Tests page to remove the dependency to the test framework.
April 2, 2019 at 18:03 #24543Brian Beuken
Participanthmmm well I don’t use unit tests and indeed its empty, so there’s nothing for me to remove
April 2, 2019 at 18:10 #24544support
KeymasterThe TestFramework.mak file would normally only be referenced when creating unit test projects, or referencing unit test frameworks. Either way, please try searching the Makefile and *.mak files for the “TestFramework” text and remove any references you find. If nothing helps, simply re-creating the project from scratch should solve the problem.
April 2, 2019 at 18:39 #24545Brian Beuken
ParticipantThere’s no reference in any of the make files to TestFramework but it always fails on this line
But where is it referencing Additional files?
April 3, 2019 at 19:41 #24559support
KeymasterSorry, there is no other place other than the .mak files in the project’s directory where ADDITIONAL_MAKE_FILES would be set.
If you are still getting strange errors, please try creating another project from scratch – it should rule out any accidental Makefile modifications that could be causing this.
