MEF Cache
Sysprogs forums Forums VisualGDB MEF Cache
Viewing 11 posts - 1 through 11 (of 11 total)
  • #6727
    kbzowski
    I have upgraded Visual Studio to 2015 and reinstalled VisualGDB 5 beta 4. Now, each time when I am trying to open any file in VisualGDB project I see:
    “Cannot connect to the smart tag backend. Do you want to attempt fixing this by resetting the MEF cache?”. I agree and restarted Visual Studio. But next time, when I am trying to open anything I see exactly the same error.
    Best regards,
    Krzysztof Bzowski
    #6735
    Can you try uninstalling VisualGDB, restarting and installing it again? If this does not help, please let us know which other VS extensions you are using.
    #6738
    kbzowski
    Uninstalling, rebooting, and installing again did not fix the problem.
    This is info about my installation. AFAIK I am using only Resharper.
    Microsoft Visual Studio Enterprise 2015 Version 14.0.23107.0 D14REL Microsoft .NET Framework Version 4.6.00081
    Installed Version: Enterprise
    Architecture and Modeling Tools   00322-80000-00000-AA476 Microsoft Architecture and Modeling Tools
    UML® and Unified Modeling Language™ are trademarks or registered trademarks of the Object Management Group, Inc. in the United States and other countries.
    LightSwitch for Visual Studio 2015   00322-80000-00000-AA476 Microsoft LightSwitch for Visual Studio 2015
    Visual Basic 2015   00322-80000-00000-AA476 Microsoft Visual Basic 2015
    Visual C# 2015   00322-80000-00000-AA476 Microsoft Visual C# 2015
    Visual C++ 2015   00322-80000-00000-AA476 Microsoft Visual C++ 2015
    Application Insights Tools for Visual Studio Package   1.0 Application Insights Tools for Visual Studio
    ASP.NET and Web Tools   14.0.20626.0 ASP.NET and Web Tools
    ASP.NET Web Frameworks and Tools 2013   5.2.30624.0 For additional information, visit http://www.asp.net/
    Common Azure Tools   1.5 Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
    GenerateUnitTest   1.0 Generates unit test code for methods in classes under test.
    JetBrains ReSharper Ultimate 2015.1.2   Build 102.0.20150721.105606 JetBrains ReSharper Ultimate package for Microsoft Visual Studio. For more information about ReSharper Ultimate, visit http://www.jetbrains.com/resharper. Copyright © 2015 JetBrains, Inc.
    Microsoft Azure Mobile Services Tools   1.4 Microsoft Azure Mobile Services Tools
    Microsoft Code Digger   0.9 Microsoft Code Digger
    Microsoft.Pex.VisualStudio   1.0 Pex
    NuGet Package Manager   3.0.0 NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
    Office Developer Tools for Visual Studio 2015 ENU   14.0.23025 Microsoft Office Developer Tools for Visual Studio 2015 ENU
    PreEmptive Analytics Visualizer   1.2 Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
    SQL Server Data Tools   14.0.50616.0 Microsoft SQL Server Data Tools
    VisualGDB   5.0 Allows developing and debugging Embedded, Linux, Android and other GCC/GDB-based applications with Visual Studio.
    Workflow Manager Tools 1.0   1.0 This package contains the necessary Visual Studio integration components for Workflow Manager.
    • This reply was modified 10 years, 8 months ago by kbzowski.
    #6742
    btbass
    I get the same problem using the Community version?
    #6743
    a.gerold
    I got the same problem after updating from Visual Studio 2015 Enterprise RC to Visual Studio 2015 Enterprise.
    I uninstalled the RC Version incl. Visual GDB 5 beta, then installed Visual Studio 2015 Enterprise & Visual GDB 5 beta again.
    The pop-up comes up everytime I open a sourcefile for editing or searching.
    #6754
    lain
    I am also experiencing this issue with Visual Studio 2015 Enterprise & Visual GDB 5.0 beta 4, and I had also recently uninstalled VS 2015 RC to update to the release version. The pop-up shows every time I open a source file for editing or searching as well.
    #6755
    Thanks everyone, we got a repro. Looks like the final build of VS2015 initializes editor extensions in a different way causing a problem with VisualGDB. We will release a hotfix within the next 24 hours.
    #6757
    #6758
    lain
    Bazis, I am no longer getting the error with the build you linked 🙂
    However, I’m not seeing the smart tags for renaming things. My testing is on an Embedded project written in C++, I haven’t tried other project types to see if they exhibit the same problem.
    #6759
    lain
    Bazis, disregard my mention of the smart tag issue — I was just doing it wrong, it’s working fine!
    #6761
    kbzowski
    It fixed the problem. Thank you.
