We’ve been using VisualGDB for a few months now, and here is some poor interactions with our source control solution (Vault) that we’ve encountered:
- The Makefile is not automatically checked out for edition from the source control when adding / removing a file from the project (or when modifying VisualGDB Makefile Project Properties)
- The Makefile is not modified
- When the Makefile is manually checked out, we have to add and remove a dummy file from the project to force the update of the Makefile
- .vgdbsettings files are not automatically added to source control when creating a project
- .vgdbsettings files are not automatically checked out when editing the VisualGDB Project Properties
- It also often happens that VisualGDB creates .bak files from files under source control at some point. Those .bak files are read-only. When VisualGDB attempts to overwrite it with a new .bak file, we get an error because the file is read-only. Suggestion: force the deletion of the .bak file even if it is read-only before writing a new one.
Beside that, we’re delighted with the features of VisualGDB.
