Live Memory Engine prevents Live Variables to be shown
Sysprogs forums Forums VisualGDB Live Memory Engine prevents Live Variables to be shown
  • #9802
    mico666
    everytime I stop a debugging session with Live Memory Engine and Live Variables enabled I don’t see the Live Variables in the next debugging session. So I always have to disable the Live Memory Engine prior to stopping the debugging session to have the Live Variables shown in the next session. It seems, that the vgdbsettings.user file won’t be loaded completely when the Live Memory Engine is enabled. I’m on VisualGDB 5.2r4 and have seen this issue in different versions as well. I’m wondering if someone else has seen this behavior?
    Best regards
    Michael
    #9804
    Based on your description, you have set Live Variables to some scope-dependent objects (e.g. static members of a class) without using the full scope (e.g. s_Variable instead of MyClass::s_Variable). Next time you start the debugging session, VisualGDB would evaluate ‘s_Variable’ when the program starts, not find it (because the program is not in the scope of MyClass yet) and consider it deleted. Please try using fully qualified names for your variables to fix this.
    If you are not sure, please switch the GDB Session window to All GDB Output mode and check for commands trying to evaluate the variables you added in the previous session. The output from gdb should explain why they fail.
    #9808
    mico666
    thank you for the quick response. The variables are in the global scope in a C project and  VisualGDB finds them everytime I start a debugging session, but when in the last debugging session a memory window with live memory was active and the session was stopped and started again the variables are not visible. When I then disable the Live Memory Engine in the memory window, stop the debugging session and start it again the variables become visible again.
    #9809
    mico666
    I made a short video that makes this behavior clear: https://drive.google.com/open?id=0B5WiEZNPXgbET2NfcTJmY29VRFE
    The GDB output of a working debugging session:
    C:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi C:\EmbeddedProject6\VisualGDB\Debug\EmbeddedProject6
    [       0 ms] -gdb-version
    [      45 ms] =thread-group-added,id=”i1″
    [      45 ms] ~”GNU gdb (GDB) 7.12\n”
    [      45 ms] ~”Copyright (C) 2016 Free Software Foundation, Inc.\n”
    [      46 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law.  Type \”show copying\”\nand \”show warranty\” for details.\n”
    [      46 ms] ~”This GDB was configured as \”–host=i686-pc-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
    [      47 ms] ~”\nFor bug reporting instructions, please see:\n”
    [      47 ms] ~”<http://www.gnu.org/software/gdb/bugs/&gt;.\n”
    [      47 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/&gt;.\n”
    [      47 ms] ~”For help, type \”help\”.\n”
    [      47 ms] ~”Type \”apropos word\” to search for commands related to \”word\”…\n”
    [      49 ms] ~”Reading symbols from C:\\EmbeddedProject6\\VisualGDB\\Debug\\EmbeddedProject6…”
    [      51 ms] ~”done.\n”
    [      52 ms] ~”GNU gdb (GDB) 7.12\n”
    [      52 ms] ~”Copyright (C) 2016 Free Software Foundation, Inc.\n”
    [      53 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law.  Type \”show copying\”\nand \”show warranty\” for details.\n”
    [      53 ms] ~”This GDB was configured as \”–host=i686-pc-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
    [      53 ms] ~”\nFor bug reporting instructions, please see:\n”
    [      54 ms] ~”<http://www.gnu.org/software/gdb/bugs/&gt;.\n”
    [      54 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/&gt;.\n”
    [      54 ms] ~”For help, type \”help\”.\n”
    [      54 ms] ~”Type \”apropos word\” to search for commands related to \”word\”.\n”
    [      54 ms] ^done
    [      54 ms] -list-features
    [      55 ms] ^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”]
    [      55 ms] -gdb-set disassembly-flavor intel
    [      56 ms] ^error,msg=”No symbol \”disassembly\” in current context.”
    [      56 ms] -gdb-set print demangle off
    [      56 ms] ^done
    [      57 ms] -break-insert -f main
    [      66 ms] ^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″,thread-groups=[“i1″],times=”0″,original-location=”main”}
    [      67 ms] set remotetimeout 60
    [      67 ms] &”set remotetimeout 60\n”
    [      67 ms] =cmd-param-changed,param=”remotetimeout”,value=”60″
    [      67 ms] ^done
    [      67 ms] target remote :1780
    [      67 ms] &”target remote :1780\n”
    [      73 ms] ~”Remote debugging using :1780\n”
    [      80 ms] =thread-group-started,id=”i1″,pid=”42000″
    [      80 ms] =thread-created,id=”1″,group-id=”i1″
    [      87 ms] ~”Reset_Handler () at C:/Users/anders/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F3xxxx/StartupFiles/startup_stm32f303xe.c:886\n”
    [      87 ms] ~”886\t\tfor (pSource = &_sidata, pDest = &_sdata; pDest != &_edata; pSource++, pDest++)\n”
    [      88 ms] *stopped,frame={addr=”0x08000288″,func=”Reset_Handler”,args=[],file=”C:/Users/anders/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F3xxxx/StartupFiles/startup_stm32f303xe.c”,fullname=”C:\\Users\\anders\\AppData\\Local\\VisualGDB\\EmbeddedBSPs\\arm-eabi\\com.sysprogs.arm.stm32\\STM32F3xxxx\\StartupFiles\\startup_stm32f303xe.c”,line=”886″},thread-id=”1″,stopped-threads=”all”
    [      89 ms] ^done
    [      89 ms] info shared
    [      99 ms] &”info shared\n”
    [      99 ms] ~”No shared libraries loaded at this time.\n”
    [      99 ms] ^done
    [      99 ms] mon halt
    [      99 ms] &”mon halt\n”
    [     101 ms] ^done
    [     101 ms] mon reset init
    [     102 ms] &”mon reset init\n”
    [     103 ms] @”Unable to match requested speed 1000 kHz, using 950 kHz\n”
    [     104 ms] @”Unable to match requested speed 1000 kHz, using 950 kHz\n”
    [     104 ms] @”adapter speed: 950 kHz\n”
    [     192 ms] @”stm32f3x.cpu: target state: halted\n”
    [     192 ms] @”target halted due to debug-request, current mode: Thread \n”
    [     193 ms] @”xPSR: 0x01000000 pc: 0x08000288 msp: 0x20010000\n”
    [     211 ms] @”Unable to match requested speed 8000 kHz, using 4000 kHz\n”
    [     212 ms] @”Unable to match requested speed 8000 kHz, using 4000 kHz\n”
    [     212 ms] @”adapter speed: 4000 kHz\n”
    [     215 ms] ^done
    [     215 ms] load
    [     215 ms] &”load\n”
    [     377 ms] ~”Loading section .isr_vector, size 0x194 lma 0x8000000\n”
    [     378 ms] +download,{section=”.isr_vector”,section-size=”404″,total-size=”41622″}
    [     378 ms] +download,{section=”.isr_vector”,section-sent=”404″,section-size=”404″,total-sent=”404″,total-size=”41622″}
    [     378 ms] ~”Loading section .text, size 0x870 lma 0x8000194\n”
    [     379 ms] +download,{section=”.text”,section-size=”2160″,total-size=”41622″}
    [     379 ms] ~”Loading section .init_array, size 0x4 lma 0x8000a04\n”
    [     380 ms] +download,{section=”.init_array”,section-size=”4″,total-size=”41622″}
    [     380 ms] ~”Loading section .fini_array, size 0x4 lma 0x8000a08\n”
    [     380 ms] +download,{section=”.fini_array”,section-size=”4″,total-size=”41622″}
    [     381 ms] ~”Loading section .data, size 0x4 lma 0x8000a0c\n”
    [     381 ms] +download,{section=”.data”,section-size=”4″,total-size=”41622″}
    [     634 ms] ~”Start address 0x8000288, load size 2576\n”
    [     639 ms] ~”Transfer rate: 6 KB/sec, 515 bytes/write.\n”
    [     640 ms] ^done
    [     640 ms] -data-evaluate-expression “sizeof(void *)”
    [     640 ms] ^done,value=”4″
    [     640 ms] -data-evaluate-expression “sizeof(int)”
    [     640 ms] -data-evaluate-expression “sizeof(short)”
    [     641 ms] ^done,value=”2″
    [     641 ms] -data-evaluate-expression “sizeof(long)”
    [     651 ms] ^done,value=”4″
    [     651 ms] -data-evaluate-expression “sizeof(long long)”
    [     651 ms] ^done,value=”8″
    [     651 ms] -data-evaluate-expression “sizeof(char)”
    [     652 ms] ^done,value=”1″
    [     652 ms] -data-evaluate-expression “sizeof(wchar_t)”
    [     652 ms] ^error,msg=”No symbol \”wchar_t\” in current context.”
    [     652 ms] -data-evaluate-expression “sizeof(float)”
    [     652 ms] ^done,value=”4″
    [     652 ms] -data-evaluate-expression “sizeof(double)”
    [     653 ms] ^done,value=”8″
    [     653 ms] -data-evaluate-expression “sizeof(long double)”
    [     699 ms] x/32xb 0x20000000
    [     703 ms] &”x/32xb 0x20000000\n”
    [     710 ms] ~”0x20000000 <SystemCoreClock>:\t0x16\t0x68\t0x00\t0x2e\t0x18\t0xd0\t0x55\t0x68\n”
    [     718 ms] ~”0x20000008 <object.6502>:\t0xb5\t0x42\t0xf9\t0xd0\t0x2e\t0x88\t0x26\t0x80\n”
    [     727 ms] ~”0x20000010 <object.6502+8>:\t0x02\t0x35\t0x02\t0x34\t0xc6\t0x68\t0x01\t0x27\n”
    [     736 ms] ~”0x20000018 <object.6502+16>:\t0x3e\t0x42\t0xfb\t0xd1\t0x14\t0x27\t0x3e\t0x42\n”
    [     736 ms] ^done
    [     740 ms] -var-create – * “&(i)”
    [     746 ms] ^done,name=”var1″,numchild=”1″,value=”0x20000028 <i>”,type=”int *”,has_more=”0″
    [     746 ms] -var-create – * “i”
    [     748 ms] ^done,name=”var2″,numchild=”0″,value=”1616196872″,type=”int”,has_more=”0″
    [    1753 ms] -var-create – * “&(j)”
    [    1758 ms] ^done,name=”var3″,numchild=”1″,value=”0x20000024 <j>”,type=”int *”,has_more=”0″
    [    1761 ms] -var-create – * “j”
    [    1779 ms] ^done,name=”var4″,numchild=”0″,value=”1175835393″,type=”int”,has_more=”0″
    [    1784 ms] -var-delete “var1″
    [    1790 ms] ^done,ndeleted=”1”
    [    1790 ms] -var-delete “var2″
    [    1790 ms] -var-delete “var3″
    [    1790 ms] ^done,ndeleted=”1″
    [    1811 ms] info target
    [    1820 ms] &”info target\n”
    [    1820 ms] ~”Symbols from \”C:\\EmbeddedProject6\\VisualGDB\\Debug\\EmbeddedProject6\”.\n”
    [    1820 ms] ~”Remote serial target in gdb-specific protocol:\n”
    [    1820 ms] ~”Debugging a target over a serial line.\n”
    [    1821 ms] ~”\tWhile running this, GDB does not access memory from…\n”
    [    1821 ms] ~”Local exec file:\n”
    [    1821 ms] ~”\t`C:\\EmbeddedProject6\\VisualGDB\\Debug\\EmbeddedProject6′, file type elf32-littlearm.\n”
    [    1821 ms] ~”\tEntry point: 0x8000288\n”
    [    1821 ms] ~”\t0x08000000 – 0x08000194 is .isr_vector\n”
    [    1822 ms] ~”\t0x08000194 – 0x08000a04 is .text\n”
    [    1822 ms] ~”\t0x08000a04 – 0x08000a08 is .init_array\n”
    [    1822 ms] ~”\t0x08000a08 – 0x08000a0c is .fini_array\n”
    [    1822 ms] ~”\t0x20000000 – 0x20000004 is .data\n”
    [    1822 ms] ~”\t0x20000004 – 0x2000002c is .bss\n”
    [    1822 ms] ^done
    [    1856 ms] -data-evaluate-expression “&_estack”
    [    1871 ms] ^done,value=”0x20010000″
    [    1871 ms] -var-create – * “*((void **)0x2000fffc)”
    [    1887 ms] ^done,name=”var5″,numchild=”0″,value=”0x80002b9 <Reset_Handler+48>”,type=”void *”,has_more=”0″
    [    1887 ms] -var-assign “var5″ 0x697f6360
    [    1887 ms] ^done,value=”0x697f6360”
    [    1887 ms] -data-evaluate-expression “\*\(\(void\ \*\*\)0x2000fffc\)”
    [    1887 ms] ^done,value=”0x697f6360″
    [    1887 ms] -exec-continue
    [    1887 ms] ^running
    [    1887 ms] *running,thread-id=”all”
    [    1887 ms] ~”Note: automatically using hardware breakpoints for read-only addresses.\n”
    [    2074 ms] =breakpoint-modified,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″,thread-groups=[“i1″],times=”1″,original-location=”main”}
    [    2090 ms] ~”\n”
    [    2090 ms] ~”Breakpoint 1, main () at LEDBlink.c:18\n”
    [    2090 ms] ~”18\t\tHAL_Init();\n”
    [    2090 ms] *stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”1″,frame={addr=”0x080008d6″,func=”main”,args=[],file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″},thread-id=”1″,stopped-threads=”all”
    [    2090 ms] -stack-list-frames –thread 1
    [    2105 ms] ^done,stack=[frame={level=”0″,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″}]
    [    2105 ms] -stack-list-arguments –thread 1 1
    [    2121 ms] ^done,stack-args=[frame={level=”0″,args=[]}]
    [    2121 ms] -stack-list-frames –thread 1
    [    2137 ms] ^done,stack=[frame={level=”0″,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″}]
    [    2137 ms] -stack-list-arguments –thread 1 1
    [    2137 ms] ^done,stack-args=[frame={level=”0″,args=[]}]
    [    2152 ms] x/32xb 0x20000000
    [    2168 ms] &”x/32xb 0x20000000\n”
    [    2183 ms] ~”0x20000000 <SystemCoreClock>:\t0x00\t0x12\t0x7a\t0x00\t0x00\t0x00\t0x00\t0x00\n”
    [    2199 ms] ~”0x20000008 <object.6502>:\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\n”
    [    2199 ms] ~”0x20000010 <object.6502+8>:\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\n”
    [    2215 ms] ~”0x20000018 <object.6502+16>:\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\t0x00\n”
    [    2215 ms] ^done
    [    4867 ms] -gdb-exit
    [    4882 ms] ^exit
    [    4882 ms] =thread-group-exited,id=”i1″
    GDB output of a non working session:
    [      37 ms] =thread-group-added,id=”i1″
    [      37 ms] ~”GNU gdb (GDB) 7.12\n”
    [      38 ms] ~”Copyright (C) 2016 Free Software Foundation, Inc.\n”
    [      38 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law.  Type \”show copying\”\nand \”show warranty\” for details.\n”
    [      39 ms] ~”This GDB was configured as \”–host=i686-pc-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
    [      39 ms] ~”\nFor bug reporting instructions, please see:\n”
    [      39 ms] ~”<http://www.gnu.org/software/gdb/bugs/&gt;.\n”
    [      39 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/&gt;.\n”
    [      40 ms] ~”For help, type \”help\”.\n”
    [      40 ms] ~”Type \”apropos word\” to search for commands related to \”word\”…\n”
    [      41 ms] ~”Reading symbols from C:\\EmbeddedProject6\\VisualGDB\\Debug\\EmbeddedProject6…”
    [      42 ms] ~”done.\n”
    [      43 ms] ~”GNU gdb (GDB) 7.12\n”
    [      44 ms] ~”Copyright (C) 2016 Free Software Foundation, Inc.\n”
    [      44 ms] ~”License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law.  Type \”show copying\”\nand \”show warranty\” for details.\n”
    [      45 ms] ~”This GDB was configured as \”–host=i686-pc-mingw32 –target=arm-eabi\”.\nType \”show configuration\” for configuration details.”
    [      45 ms] ~”\nFor bug reporting instructions, please see:\n”
    [      45 ms] ~”<http://www.gnu.org/software/gdb/bugs/&gt;.\n”
    [      45 ms] ~”Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/&gt;.\n”
    [      45 ms] ~”For help, type \”help\”.\n”
    [      45 ms] ~”Type \”apropos word\” to search for commands related to \”word\”.\n”
    [      46 ms] ^done
    [      46 ms] -list-features
    [      46 ms] ^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”,”language-option”,”info-gdb-mi-command”,”undefined-command-error-code”,”exec-run-start-option”]
    [      46 ms] -gdb-set disassembly-flavor intel
    [      47 ms] ^error,msg=”No symbol \”disassembly\” in current context.”
    [      47 ms] -gdb-set print demangle off
    [      47 ms] ^done
    [      48 ms] -break-insert -f main
    [      57 ms] ^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″,thread-groups=[“i1″],times=”0″,original-location=”main”}
    [      58 ms] set remotetimeout 60
    [      58 ms] &”set remotetimeout 60\n”
    [      58 ms] =cmd-param-changed,param=”remotetimeout”,value=”60″
    [      58 ms] ^done
    [      58 ms] target remote :1796
    [      58 ms] &”target remote :1796\n”
    [      74 ms] ~”Remote debugging using :1796\n”
    [      81 ms] =thread-group-started,id=”i1″,pid=”42000″
    [      81 ms] =thread-created,id=”1″,group-id=”i1″
    [      88 ms] ~”Reset_Handler () at C:/Users/anders/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F3xxxx/StartupFiles/startup_stm32f303xe.c:886\n”
    [      89 ms] ~”886\t\tfor (pSource = &_sidata, pDest = &_sdata; pDest != &_edata; pSource++, pDest++)\n”
    [      89 ms] *stopped,frame={addr=”0x08000288″,func=”Reset_Handler”,args=[],file=”C:/Users/anders/AppData/Local/VisualGDB/EmbeddedBSPs/arm-eabi/com.sysprogs.arm.stm32/STM32F3xxxx/StartupFiles/startup_stm32f303xe.c”,fullname=”C:\\Users\\anders\\AppData\\Local\\VisualGDB\\EmbeddedBSPs\\arm-eabi\\com.sysprogs.arm.stm32\\STM32F3xxxx\\StartupFiles\\startup_stm32f303xe.c”,line=”886″},thread-id=”1″,stopped-threads=”all”
    [      89 ms] ^done
    [      99 ms] ^done
    [      99 ms] mon halt
    [     102 ms] ^done
    [     102 ms] mon reset init
    [     188 ms] @”stm32f3x.cpu: target state: halted\n”
    [     189 ms] @”target halted due to debug-request, current mode: Thread \n”
    [     189 ms] @”xPSR: 0x01000000 pc: 0x08000288 msp: 0x20010000\n”
    [     208 ms] @”Unable to match requested speed 8000 kHz, using 4000 kHz\n”
    [     210 ms] @”Unable to match requested speed 8000 kHz, using 4000 kHz\n”
    [     210 ms] @”adapter speed: 4000 kHz\n”
    [     211 ms] ^done
    [     211 ms] load
    [     211 ms] &”load\n”
    [     362 ms] ~”Loading section .isr_vector, size 0x194 lma 0x8000000\n”
    [     363 ms] +download,{section=”.isr_vector”,section-size=”404″,total-size=”41622″}
    [     363 ms] +download,{section=”.isr_vector”,section-sent=”404″,section-size=”404″,total-sent=”404″,total-size=”41622″}
    [     363 ms] ~”Loading section .text, size 0x870 lma 0x8000194\n”
    [     363 ms] +download,{section=”.text”,section-size=”2160″,total-size=”41622″}
    [     364 ms] ~”Loading section .init_array, size 0x4 lma 0x8000a04\n”
    [     364 ms] +download,{section=”.init_array”,section-size=”4″,total-size=”41622″}
    [     364 ms] ~”Loading section .fini_array, size 0x4 lma 0x8000a08\n”
    [     364 ms] +download,{section=”.fini_array”,section-size=”4″,total-size=”41622″}
    [     365 ms] ~”Loading section .data, size 0x4 lma 0x8000a0c\n”
    [     365 ms] +download,{section=”.data”,section-size=”4″,total-size=”41622″}
    [     598 ms] ~”Start address 0x8000288, load size 2576\n”
    [     603 ms] ~”Transfer rate: 6 KB/sec, 515 bytes/write.\n”
    [     604 ms] ^done
    [     604 ms] -data-evaluate-expression “sizeof(void *)”
    [     604 ms] ^done,value=”4″
    [     604 ms] -data-evaluate-expression “sizeof(int)”
    [     604 ms] -data-evaluate-expression “sizeof(short)”
    [     604 ms] ^done,value=”2″
    [     604 ms] -data-evaluate-expression “sizeof(long)”
    [     605 ms] ^done,value=”4″
    [     605 ms] -data-evaluate-expression “sizeof(long long)”
    [     605 ms] ^done,value=”8″
    [     605 ms] -data-evaluate-expression “sizeof(char)”
    [     605 ms] ^done,value=”1″
    [     605 ms] -data-evaluate-expression “sizeof(wchar_t)”
    [     615 ms] ^error,msg=”No symbol \”wchar_t\” in current context.”
    [     615 ms] -data-evaluate-expression “sizeof(float)”
    [     615 ms] ^done,value=”4″
    [     615 ms] -data-evaluate-expression “sizeof(double)”
    [     616 ms] ^done,value=”8″
    [     616 ms] -data-evaluate-expression “sizeof(long double)”
    [     689 ms] -var-create – * “&(i)”
    [     696 ms] ^done,name=”var1″,numchild=”1″,value=”0x20000028 <i>”,type=”int *”,has_more=”0″
    [     696 ms] -var-create – * “i”
    [     698 ms] ^done,name=”var2″,numchild=”0″,value=”1616196872″,type=”int”,has_more=”0″
    [     698 ms] -var-create – * “&(j)”
    [     708 ms] ^done,name=”var3″,numchild=”1″,value=”0x20000024 <j>”,type=”int *”,has_more=”0″
    [     708 ms] -var-create – * “j”
    [     709 ms] ^done,name=”var4″,numchild=”0″,value=”1175835393″,type=”int”,has_more=”0″
    [     714 ms] info target
    [     720 ms] &”info target\n”
    [     720 ms] ~”Symbols from \”C:\\EmbeddedProject6\\VisualGDB\\Debug\\EmbeddedProject6\”.\n”
    [     720 ms] ~”Remote serial target in gdb-specific protocol:\n”
    [     720 ms] ~”Debugging a target over a serial line.\n”
    [     720 ms] ~”\tWhile running this, GDB does not access memory from…\n”
    [     721 ms] ~”Local exec file:\n”
    [     721 ms] ~”\t`C:\\EmbeddedProject6\\VisualGDB\\Debug\\EmbeddedProject6′, file type elf32-littlearm.\n”
    [     721 ms] ~”\tEntry point: 0x8000288\n”
    [     721 ms] ~”\t0x08000000 – 0x08000194 is .isr_vector\n”
    [     721 ms] ~”\t0x08000194 – 0x08000a04 is .text\n”
    [     721 ms] ~”\t0x08000a04 – 0x08000a08 is .init_array\n”
    [     722 ms] ~”\t0x08000a08 – 0x08000a0c is .fini_array\n”
    [     722 ms] ~”\t0x20000000 – 0x20000004 is .data\n”
    [     722 ms] ~”\t0x20000004 – 0x2000002c is .bss\n”
    [     722 ms] ^done
    [     777 ms] -data-evaluate-expression “&_estack”
    [     792 ms] ^done,value=”0x20010000″
    [     792 ms] -var-create – * “*((void **)0x2000fffc)”
    [     792 ms] ^done,name=”var5″,numchild=”0″,value=”0x80002b9 <Reset_Handler+48>”,type=”void *”,has_more=”0″
    [     792 ms] -var-assign “var5″ 0x5c0016b9
    [     808 ms] ^done,value=”0x5c0016b9”
    [     808 ms] -data-evaluate-expression “\*\(\(void\ \*\*\)0x2000fffc\)”
    [     808 ms] ^done,value=”0x5c0016b9″
    [     808 ms] -exec-continue
    [     824 ms] ^running
    [     824 ms] *running,thread-id=”all”
    [     824 ms] ~”Note: automatically using hardware breakpoints for read-only addresses.\n”
    [    1011 ms] =breakpoint-modified,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″,thread-groups=[“i1″],times=”1″,original-location=”main”}
    [    1011 ms] ~”\n”
    [    1011 ms] ~”Breakpoint 1, main () at LEDBlink.c:18\n”
    [    1011 ms] ~”18\t\tHAL_Init();\n”
    [    1011 ms] *stopped,reason=”breakpoint-hit”,disp=”keep”,bkptno=”1″,frame={addr=”0x080008d6″,func=”main”,args=[],file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″},thread-id=”1″,stopped-threads=”all”
    [    1026 ms] -stack-list-frames –thread 1
    [    1042 ms] ^done,stack=[frame={level=”0″,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″}]
    [    1042 ms] -stack-list-arguments –thread 1 1
    [    1042 ms] ^done,stack-args=[frame={level=”0″,args=[]}]
    [    1042 ms] -stack-list-frames –thread 1
    [    1058 ms] ^done,stack=[frame={level=”0″,addr=”0x080008d6″,func=”main”,file=”LEDBlink.c”,fullname=”C:\\EmbeddedProject6\\EmbeddedProject6\\LEDBlink.c”,line=”18″}]
    [    1058 ms] -stack-list-arguments –thread 1 1
    [    1073 ms] ^done,stack-args=[frame={level=”0″,args=[]}]
    [    9638 ms] -gdb-exit
    [    9653 ms] ^exit
    [    9653 ms] =thread-group-exited,id=”i1″
    • This reply was modified 9 years, 9 months ago by mico666.
    #9814
    Thanks for the video, it really helped reproduce the problem. Turns out, it was a race condition between live variables and live memory initialization.
    We have fixed it in this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.14.1337.msi
    #9815
    mico666
    Thanks a lot for your support and for this great product. It’s working now.
