Linux embedded Quick debug don’t work
Sysprogs forums › Forums › VisualGDB › Linux embedded Quick debug don’t work
  • #858
    I am work with VisualGDB Trail Version and in the following requirements:
    1. Win-PC Editor with Visual Studio 2013
    2. The SRC code are compile on a external Linux PC with GCC toolchain
    3. The Embedded System (Linux 2.6) boot from Linux PC root-file system (Netboot)
    4. PC/Embedded ssh connection with root user and password on Embedded Host work (Putty Ehernet consol)
    5. The Embedded gdbserver Version is 7.2
    6. I define a SSH connection with IP/User/Passwort for Embedded System, screen 1
    7. and define Quick debug setup Parameters for Linux, screen 2
    screen 1
    screen 2
    Now, i start my quick start debug session failure, screen 3 and 4.
    screen 3
    screen 4
    If i use the same gdbserver Option in a separate putty session it works!, screen 5
    screen 5
    what’s wrong??? Thx for support 🙂
    #3261
    The problem happens when VisualGDB runs a temporary script that is supposed to return the Pseudo-TTY name and instead gets something that does not look like a device path. This happens because your SSHD server tries to run some commands just before executing our script. I.e. some of the initialization scripts contain a reference to /usr/bin/X11/xauth, but the file is missing due to some reason.
    Note that when you connect with PuTTY, it uses the SSH shell mode, not the SSH command mode, that uses slightly different initialization scripts. Please try looking up what file could be referring to xauth and why it is missing.
