Sysprogs forums › Forums › VisualGDB › Linux core dump analysis using Visual GDB
- This topic has 4 replies, 2 voices, and was last updated 9 years, 8 months ago by
January 17, 2017 at 13:32 #10100
bhat_a
ParticipantHi folks,
I need a help regarding analysis of Linux core dump using visual GDB.
My application is developed on visual studio 2012 and cross compiled to Linux target (using propietery tool). I have generated a core dump on this Linux system
and I want to analyze this core dump file in visual GDB.I have come across this tutorial : http://visualgdb.com/tutorials/linux/coredump/
But, one thing is that I want to do a postmortem debug using core dumps.
But in this tutorial, it attaches to the Linux system (in step 9 : Debug Linux app on : system connection).
So, how can I do a postmortem debug using coredump without attaching to Linux system ?Thanks,
January 17, 2017 at 17:36 #10108support
You can do that with the latest VisualGDB 5.2, but you would need a cross-gdb for that (you can use one of the versions shipped with our toolchains). Simply check the “Use a cross-compiler on the Windows machine” checkbox and specify the path to your gdb executable.
January 18, 2017 at 14:13 #10115bhat_a
I used the cross-gdb for our application in Quick debug feature.
Please find the image below for all the details :
https://drive.google.com/file/d/0B_4tjTG5CRMwejIwb2l6ZHRzYkk/view?usp=sharing
And then in Visual Studio 2012, I do get the following error : Cannot access memory at address (<some hex number>). Please see the image below for details :
https://drive.google.com/file/d/0B_4tjTG5CRMwZEhrOUw0OFA4eXc/view?usp=sharing
January 18, 2017 at 16:49 #10120bhat_a
ParticipantOne more update :
“use cross compiler on the windows machine” doesn’t work with Quick Debug feature. That means, Cross-GDB doesnt able to locate the call stack and other details in the core file.
But it works perfectly when I used GDB available on the Linux remote system.
But, our purpose is to do a core dump (from linux) analysis on Visual Studio locally without attaching to remote linux system. Is there any solution for this ?
January 18, 2017 at 18:42 #10123support
Looks like you are trying to view a dump related to a shared library. In that case you would need some extra steps to ensure the symbols are read properly:
- Copy the main executable that corresponds to the dump on your Windows machine and specify it in the Quick Debug settings instead of the .so file.
- Copy the .so file with symbols and any other relevant .so files to a directory on the Windows machine (e.g. c:\symbols) and run “set solib-search-path c:/symbols” via the ‘enter additional startup commands’ option so that GDB can locate the libraries.
You can check that the symbols for .so files have been loaded by running the “info shared” command via the GDB Session window. If they are not loaded, please double-check the listed libraries, symbol files and the search path.
The “cannot read memory” error is not related to symbol handling. Most likely gdb tries to some heuristics while unwinding the stack (or Visual Studio tries to follow a pointer) and reaches an area of memory that is not included in the dump file. This is normal and should not interfere with the rest of the functionality.
