Linking fails – mysql
Sysprogs forums › Forums › VisualGDB › Linking fails – mysql
  • #10829
    benlarsendk
    Hello.
    I’m trying to build a piece of software, that connects to a local db. I’m using visual gdb and visual studio 2015.
    When I try to link with the libmysqlcppconn.so, it fails:
    1> Linking CXX executable DatabaseConnection
    1> /usr/lib/libmysqlcppconn.so: file not recognized: File format not recognized
    1>collect2 : error : ld returned 1 exit status
    What am I doing wrong? I have set the library path in the settings.
    My CMakelist is:
    cmake_minimum_required(VERSION 2.7)
    project(DatabaseConnection)
    set(LIBRARIES_FROM_REFERENCES “”)
    set(CMAKE_CXX_FLAGS “${CMAKE_CXX_FLAGS} -std=c++11”)
    add_executable(DatabaseConnection DatabaseConnection.cpp LocalMySQLHandler.cpp Meassurement.cpp MSSet.cpp)
    target_link_libraries(DatabaseConnection -L/usr/lib -lmysqlcppconn “${LIBRARIES_FROM_REFERENCES}”)
    Can anyone help?
    #10830
    Looks like libmysqlcppconn.so is corrupt or taken from an incompatible system. Please double-check the file and try reinstalling the package that provides it.
