Sysprogs forums › Forums › VisualGDB › Linker fails after update to gcc arm 7.2.0
- This topic has 12 replies, 2 voices, and was last updated 8 years, 10 months ago by
sidprice.
November 11, 2017 at 01:53 #12946
sidprice
ParticipantMy toolchain was updated today and later when I opened a project that has previously worked just fine I get the following error:
c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-eabi/7.2.0/../../../../arm-eabi/bin/ld.exe: cannot find : Invalid argument
Not much information to find what the issue is and verbose output is enabled.
Sid
November 11, 2017 at 04:29 #12949support
It looks like something in the linker command line is broken. Please try enabling verbose mode via VS Project Properties -> Linker -> Advanced (not the regular VisualGDB verbose mode) and post the entire verbose build output here so that we could help you understand what is going on.
November 11, 2017 at 16:03 #12954sidprice
Participant1>—— Build started: Project: bmp_windows_build, Configuration: Release VisualGDB ——
1> command.c
1> crc32.c
1> exception.c
1> gdb_hostio.c
1> gdb_main.c
1> gdb_packet.c
1> hex_utils.c
1> main.c
1> morse.c
1> cdcacm.c
1> swdptap.c
1> timing.c
1> gdb_if.c
1> jtagtap.c
1> serialno.c
1> timing_stm32.c
1> traceswo.c
1> usbuart.c
1> cc3100.c
1> platform.c
1> WiFi_Server.c
1> device.c
1> driver.c
1> flowcont.c
1> fs.c
1> netapp.c
1> netcfg.c
1> nonos.c
1> socket.c
1> spawn.c
1> wlan.c
1> adiv5.c
1> adiv5_jtagdp.c
1> adiv5_swdp.c
1> cortexa.c
1> cortexm.c
1> efm32.c
1> jtagtap_generic.c
1> jtag_scan.c
1> kinetis.c
1> lmi.c
1> lpc11xx.c
1> lpc15xx.c
1> lpc43xx.c
1> lpc_common.c
1> nrf51.c
1> sam3x.c
1> sam4l.c
1> samd.c
1> stm32f1.c
1> stm32f4.c
1> stm32l0.c
1> stm32l4.c
1> swdptap_generic.c
1> target.c
1> Linking ../VisualGDB/Release/blackmagic.elf…
1> GNU ld (GNU Binutils) 2.29
1> Supported emulations:
1> armelf
1> opened script file platforms/stm32/f4discovery.ld
1> opened script file libopencm3_stm32f4.ld
1> using external linker script:
1> ==================================================
1> /*
1> * This file is part of the libopencm3 project.
1> *
1> * Copyright (C) 2009 Uwe Hermann <uwe@hermann-uwe.de>
1> *
1> c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-eabi/7.2.0/../../../../arm-eabi/bin/ld.exe: cannot find : Invalid argument
1> * This library is free software: you can redistribute it and/or modify
1> * it under the terms of the GNU Lesser General Public License as published by
1> * the Free Software Foundation, either version 3 of the License, or
1> * (at your option) any later version.
1> *
1> * This library is distributed in the hope that it will be useful,
1> * but WITHOUT ANY WARRANTY; without even the implied warranty of
1> * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
1> * GNU Lesser General Public License for more details.
1> *
1> * You should have received a copy of the GNU Lesser General Public License
1> * along with this library. If not, see <http://www.gnu.org/licenses/>.
1> */
1>
1> /* Generic linker script for STM32 targets using libopencm3. */
1>
1> /* Memory regions must be defined in the ld script which includes this one. */
1>
1> /* Enforce emmition of the vector table. */
1> EXTERN (vector_table)
1>
1> /* Define the entry point of the output file. */
1> ENTRY(reset_handler)
1>
1> /* Define sections. */
1> SECTIONS
1> {
1> .text : {
1> *(.vectors) /* Vector table */
1> *(.text*) /* Program code */
1> . = ALIGN(4);
1> *(.rodata*) /* Read-only data */
1> . = ALIGN(4);
1> } >rom
1>
1> /* C++ Static constructors/destructors, also used for __attribute__
1> * ((constructor)) and the likes */
1> .preinit_array : {
1> . = ALIGN(4);
1> __preinit_array_start = .;
1> KEEP (*(.preinit_array))
1> __preinit_array_end = .;
1> } >rom
1> .init_array : {
1> . = ALIGN(4);
1> __init_array_start = .;
1> KEEP (*(SORT(.init_array.*)))
1> KEEP (*(.init_array))
1> __init_array_end = .;
1> } >rom
1> .fini_array : {
1> . = ALIGN(4);
1> __fini_array_start = .;
1> KEEP (*(.fini_array))
1> KEEP (*(SORT(.fini_array.*)))
1> __fini_array_end = .;
1> } >rom
1>
1> /*
1> * Another section used by C++ stuff, appears when using newlib with
1> * 64bit (long long) printf support
1> */
1> .ARM.extab : {
1> *(.ARM.extab*)
1> } >rom
1> .ARM.exidx : {
1> __exidx_start = .;
1> *(.ARM.exidx*)
1> __exidx_end = .;
1> } >rom
1>
1> . = ALIGN(4);
1> _etext = .;
1>
1> .data : {
1> _data = .;
1> *(.data*) /* Read-write initialized data */
1> . = ALIGN(4);
1> _edata = .;
1> } >ram AT >rom
1> _data_loadaddr = LOADADDR(.data);
1>
1> .bss : {
1> *(.bss*) /* Read-write zero initialized data */
1> *(COMMON)
1> . = ALIGN(4);
1> _ebss = .;
1> } >ram
1>
1> /*
1> * The .eh_frame section appears to be used for C++ exception handling.
1> * You may need to fix this if you’re using C++.
1> */
1> /DISCARD/ : { *(.eh_frame) }
1>
1> . = ALIGN(4);
1> end = .;
1> }
1>
1> PROVIDE(_stack = ORIGIN(ram) + LENGTH(ram));
1>
1>
1> attempt to open failed
========== Build: 0 succeeded, 1 failed, 1 up-to-date, 0 skipped ==========November 11, 2017 at 18:14 #12955support
Thanks for the build log. Unfortunately it looks like an error that happens before the Linker manages to output enough information.
Please try locating the Release\Debug\<ProjectName>.link.rsp file and post its content here (please also attach your <mcu>.props file from the project directory). The file should contain the linker command line and should help us see what could be wrong.
If you see something suspicious in the file, please try running the following command from the project directory:
<full path to arm-eabi-gcc> @Release\Debug\<ProjectName>.link.rsp
If you can reproduce the same error, try removing the suspicious part and run GCC again. If you can successfully pinpoint a part that is causing an error, please edit your settings accordingly.
November 11, 2017 at 18:22 #12956sidprice
Participant.link.rsp file:
-o ../VisualGDB/Release/blackmagic.elf -L../VisualGDB/Release -Wl,-gc-sections -Wl,-verbose -Wl,–defsym,_stack=0x20006000, -Wl,-T,platforms/stm32/f4discovery.ld -nostartfiles -lc -lnosys -Wl,-Map=mapfile -mthumb -mcpu=cortex-m4 -Wl,-gc-sections, -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mcpu=cortex-m4 -Wl,–start-group VisualGDB/Release/command.o VisualGDB/Release/crc32.o VisualGDB/Release/exception.o VisualGDB/Release/gdb_hostio.o VisualGDB/Release/gdb_main.o VisualGDB/Release/gdb_packet.o VisualGDB/Release/hex_utils.o VisualGDB/Release/main.o VisualGDB/Release/morse.o VisualGDB/Release/cdcacm.o VisualGDB/Release/swdptap.o VisualGDB/Release/timing.o VisualGDB/Release/gdb_if.o VisualGDB/Release/jtagtap.o VisualGDB/Release/serialno.o VisualGDB/Release/timing_stm32.o VisualGDB/Release/traceswo.o VisualGDB/Release/usbuart.o VisualGDB/Release/cc3100.o VisualGDB/Release/platform.o VisualGDB/Release/WiFi_Server.o VisualGDB/Release/device.o VisualGDB/Release/driver.o VisualGDB/Release/flowcont.o VisualGDB/Release/fs.o VisualGDB/Release/netapp.o VisualGDB/Release/netcfg.o VisualGDB/Release/nonos.o VisualGDB/Release/socket.o VisualGDB/Release/spawn.o VisualGDB/Release/wlan.o VisualGDB/Release/adiv5.o VisualGDB/Release/adiv5_jtagdp.o VisualGDB/Release/adiv5_swdp.o VisualGDB/Release/cortexa.o VisualGDB/Release/cortexm.o VisualGDB/Release/efm32.o VisualGDB/Release/jtagtap_generic.o VisualGDB/Release/jtag_scan.o VisualGDB/Release/kinetis.o VisualGDB/Release/lmi.o VisualGDB/Release/lpc11xx.o VisualGDB/Release/lpc15xx.o VisualGDB/Release/lpc43xx.o VisualGDB/Release/lpc_common.o VisualGDB/Release/nrf51.o VisualGDB/Release/sam3x.o VisualGDB/Release/sam4l.o VisualGDB/Release/samd.o VisualGDB/Release/stm32f1.o VisualGDB/Release/stm32f4.o VisualGDB/Release/stm32l0.o VisualGDB/Release/stm32l4.o VisualGDB/Release/swdptap_generic.o VisualGDB/Release/target.o -lopencm3_stm32f4 -Wl,–end-group
Sid
November 11, 2017 at 18:28 #12957support
KeymasterThe RSP file looks OK. As a quick check, could you try creating a new “LEDBlink” project with the same toolchain? If it doesn’t work, please try reinstalling the toolchain.
If it does, please try comparing both RSP files.
November 11, 2017 at 18:39 #12958sidprice
ParticipantI built the Led Blink project fine.
Trying to compare the two RSP files is very hard because my project is using libOpenCM3 so options are very different.
Sid
November 11, 2017 at 18:57 #12959support
We would advise trying to minimize both command lines as long as they still produce different results.
E.g. try removing all .o files from the opencm3 command line and check if you get the same cryptic error or an actual “missing entry point” error. If the message is still cryptic, try replacing the linker script with the normal linker script and if it doesn’t change anything, try removing other options.
November 11, 2017 at 20:08 #12963sidprice
ParticipantJust not getting anywhere with this. I have removed the options one-at-a-time and I still see the same error.
Sid
November 11, 2017 at 20:15 #12964sidprice
ParticipantSince I need to make progress on my project I switched back to the previous toolchain and my project now compiles. More than a little worrying that there is some incompatibility between my solution and the new toolchain.
even more concerning is that it seems almost impossible to debug the problem :{
Sid
November 12, 2017 at 05:34 #12968support
We have managed to reproduce the problem from the template file you attached in another thread and it looks like the the problem is caused by the extra comma after some arguments in your command line, e.g.:
-Wl,--defsym,_stack=0x20006000,
should be
We agree that the error message shown by gcc is not very informative and extremely cryptic, although it would be beyond our capacity to maintain and ship a special fork of GCC resolving such issues. Our best advice would be to try contacting the GCC mailing lists to see if anyone there is willing to fix this.
November 12, 2017 at 15:59 #12972sidprice
ParticipantThanks, does this mean I can update the toolchain? If so how do I get VGDB to do that,
Sid
November 12, 2017 at 16:08 #12973sidprice
ParticipantI found how to update the toolchain and also an additional “,” in the linker opitons, now my project builds fine with the new toolchain. Many thanks.
Sid
