Sysprogs forums › Forums › VisualGDB › libzmq Cmake project builds with TDM w64 compiler but not c:\SysGCC\mingw64\
- This topic has 1 reply, 2 voices, and was last updated 7 years, 11 months ago by
May 17, 2018 at 22:48 #20945
b.timofte
ParticipantDear all
I took the project via command git clone https://github.com/zeromq/libzmq after i installed git for windows
Then i used the Visual studio 2017 and CMAKE project import to import the cmake project . I selected the toolchain c:\SysGCC\mingw64\ and when i build it i go the error
—— Build started: Project: WindowsProject1.vgdbcmake, Configuration: Debug VisualGDB ——
Reconfiguring project due to missing Makefile…
Detecting C compile features – done
Check for working CXX compiler: C:/SysGCC/mingw64/bin/g++.exe
Check for working CXX compiler: C:/SysGCC/mingw64/bin/g++.exe — works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info – done
Detecting CXX compile features
Detecting CXX compile features – done
Performing Test COMPILER_SUPPORTS_CXX11
Performing Test COMPILER_SUPPORTS_CXX11 – Success
Performing Test COMPILER_SUPPORTS_C11
Performing Test COMPILER_SUPPORTS_C11 – Success
Using tweetnacl for CURVE security
Looking for kqueue
Looking for kqueue – not found
Looking for epoll_create
Looking for epoll_create – not found
Looking for sys/types.h
Looking for sys/types.h – found
Looking for stdint.h
Looking for stdint.h – found
Looking for stddef.h
Looking for stddef.h – found
Check size of struct pollfd
Check size of struct pollfd – failed
Looking for pollset_create
Looking for pollset_create – not found
Looking for poll
Looking for poll – not found
Detected select polling method
Detected ZMQ Version – 4.3.1
Looking for include file ifaddrs.h
Looking for include file ifaddrs.h – not found
Looking for include file windows.h
Looking for include file windows.h – found
Looking for include file sys/uio.h
Looking for include file sys/uio.h – not found
Looking for include file sys/eventfd.h
Looking for include file sys/eventfd.h – not found
Looking for WSAStartup
Looking for WSAStartup – found
Looking for UuidCreateSequential
Looking for UuidCreateSequential – found
Looking for GetAdaptersAddresses
Looking for GetAdaptersAddresses – found
Looking for fopen in ws2
Looking for fopen in ws2 – not found
Looking for pthread.h
Looking for pthread.h – found
Looking for pthread_create
Looking for pthread_create – not found
Looking for pthread_create in pthreads
Looking for pthread_create in pthreads – not found
Looking for pthread_create in pthread – found
Found Threads: TRUE
Looking for clock_gettime
Looking for clock_gettime – not found
Looking for fork
Looking for fork – not found
Looking for gethrtime
Looking for gethrtime – not found
Looking for mkdtemp
Looking for mkdtemp – not found
Looking for accept4
Looking for accept4 – not found
Performing Test HAVE_FLAG_-Wall
Performing Test HAVE_FLAG_-Wall – Success
Performing Test HAVE_FLAG_-Wextra
Performing Test HAVE_FLAG_-Wextra – Success
Performing Test HAVE_FLAG_-Wno-long-long
Performing Test HAVE_FLAG_-Wno-long-long – Success
Performing Test HAVE_FLAG_-Wno-uninitialized
Performing Test HAVE_FLAG_-Wno-uninitialized – Success
Performing Test HAVE_FLAG_-pedantic
Performing Test HAVE_FLAG_-pedantic – Success
Could NOT find PythonInterp (missing: PYTHON_EXECUTABLE)
Could NOT find AsciiDoc (missing: ASCIIDOC_EXECUTABLE)
CMake Warning (dev) at tests/CMakeLists.txt:240 (message):
Test ‘test_security_gssapi’ is not known to CTest.
This warning is for project developers. Use -Wno-dev to suppress it.Configuring done
Generating done
Code model queried in 231 msec
Generating done
Code model queried in 218 msec
VisualGDB: Run “C:\SysGCC\mingw64\bin\mingw32-make.exe ” in directory “C:\Users\timo\Source\Repos\WindowsProject1\WindowsProject1\..\..\..\..\Desktop\mathworks-SimulinkCoSimulationExample-148c418\libzmq/VisualGDB/Debug” on local computer
Scanning dependencies of target libzmq
[ 0%] Building C object CMakeFiles/libzmq.dir/src/tweetnacl.c.obj
[ 1%] Building CXX object CMakeFiles/libzmq.dir/src/precompiled.cpp.obj
In file included from c:\sysgcc\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.7.1/../../../../x86_64-w64-mingw32/include/mprapi.h:10:0,
from c:\sysgcc\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.7.1/../../../../x86_64-w64-mingw32/include/iprtrmib.h:9,
from c:\sysgcc\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.7.1/../../../../x86_64-w64-mingw32/include/iphlpapi.h:13,
from C:/Users/timo/Desktop/mathworks-SimulinkCoSimulationExample-148c418/libzmq/src/windows.hpp:61,
from C:/Users/timo/Desktop/mathworks-SimulinkCoSimulationExample-148c418/libzmq/src/precompiled.hpp:49,
from C:/Users/timo/Desktop/mathworks-SimulinkCoSimulationExample-148c418/libzmq/src/precompiled.cpp:30:
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\ras.h(988,3): error : ‘IsolationState’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\ras.h(989,3): error : ‘ProbationTime’ does not name a type
In file included from c:\sysgcc\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.7.1/../../../../x86_64-w64-mingw32/include/iphlpapi.h:16:0,
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(43,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(55,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(63,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(78,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(151,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(182,3): error : ‘NDIS_MEDIUM’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(183,3): error : ‘NDIS_PHYSICAL_MEDIUM’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(249,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(250,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(253,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(272,3): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(381,9): error : ‘PSOCKADDR_IN6’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(383,9): error : ‘PSOCKADDR_IN6’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(386,3): error : ‘PSOCKADDR_IN6_PAIR’ has not been declared
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(453,9): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(454,9): error : ‘SOCKADDR_INET’ does not name a type
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(457,3): error : ‘SOCKADDR_INET’ has not been declared
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\netioapi.h(584,9): error : ‘SOCKADDR_INET’ does not name a type
In file included from C:/Users/timo/Desktop/mathworks-SimulinkCoSimulationExample-148c418/libzmq/src/windows.hpp:61:0,
c:\sysgcc\mingw64\bin\..\lib\gcc\x86_64-w64-mingw32\4.7.1\..\..\..\..\x86_64-w64-mingw32\include\iphlpapi.h(147,5): error : ‘SOCKADDR_IN6’ does not name a type
mingw32-make[2]: *** [CMakeFiles/libzmq.dir/src/precompiled.cpp.obj] Error 1
mingw32-make[1]: *** [CMakeFiles/libzmq.dir/all] Error 2
mingw32-make: *** [all] Error 2
Command exited with code 2
Executable: C:\SysGCC\mingw64\bin\mingw32-make.exe
Arguments:
Directory: C:\Users\timo\Source\Repos\WindowsProject1\WindowsProject1\..\..\..\..\Desktop\mathworks-SimulinkCoSimulationExample-148c418\libzmq/VisualGDB/Debug
VisualGDB: Error: Command-line action failed
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========Then i switched to TDM-GCC-64 compiler and it worked …
VisualGDB: Run “C:\TDM-GCC-64\bin\mingw32-make.exe -j4 -i” in directory “C:\Users\timo\Source\Repos\WindowsProject1\WindowsProject1\..\..\..\..\Desktop\mathworks-SimulinkCoSimulationExample-148c418\libzmq/VisualGDB/Debug” on local computer
Scanning dependencies of target unity
[ 0%] Building C object tests/CMakeFiles/unity.dir/__/external/unity/unity.c.obj
[ 1%] Linking C static library ../lib/libunity.a
[ 1%] Built target unity
Scanning dependencies of target libzmq-static
[ 2%] Building C object CMakeFiles/libzmq-static.dir/src/tweetnacl.c.obj
[ 2%] Building C object CMakeFiles/libzmq.dir/src/tweetnacl.c.obj
[ 2%] Building CXX object CMakeFiles/libzmq-static.dir/src/precompiled.cpp.o….
[100%] Linking CXX executable ../bin/test_dgram.exe
[100%] Built target test_scatter_gather
[100%] Built target test_dgram
[100%] Linking CXX executable ../bin/test_app_meta.exe
[100%] Built target test_app_meta
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========Whats the issue ?
May 18, 2018 at 00:09 #20946support
It looks like your project relies on some functionality that is not present in our toolchain. The only known workaround to this would be to try downloading a toolchain from a different source (there are a few independent MinGW builds available online) or switching to Cygwin that is actively maintained, patched and is fully supported by VisualGDB.
