[known issue] VisualGDB Project Properties on VS2010
Sysprogs forums › Forums › VisualGDB › [known issue] VisualGDB Project Properties on VS2010
Viewing 1 post (of 1 total)
  • #6637
    Just in case someone else encounters this problem: on VS2010 when Solution Explorer is closed, opening VisualGDB Project Properties via the Project menu will result in the following error:
    80004005 E_FAIL
    This is caused by a bug in VS2010 and can be solved by keeping the Solution Explorer visible or updating to VS2012 or later.
