j-trace pro not recognized on usb
Sysprogs forums › Forums › VisualGDB › j-trace pro not recognized on usb
Viewing 2 posts - 16 through 17 (of 17 total)
  • #23629
    wolpi
    I tried to put in the known values,
    <ProgrammingInterface>
    <ID>jtrace</ID>
    <Name>Segger J-Trace</Name>
    <Identities>
    <UsbIdentity>
    <VID>1366</VID>
    <PID>1020</PID>
    </UsbIdentity>
    </Identities>
    <UniversalDriverId>com.sysprogs.libusb.mini</UniversalDriverId>
    <AutoSelectPriority>0</AutoSelectPriority>
    </ProgrammingInterface>
    now you can choose it, but the test still fails:
    C:\Users\bodo\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 53245” -c “telnet_port 53246” -f interface/jlink.cfg -c “adapter_khz 3000” -f target/esp32.cfg -c “echo VisualGDB_OpenOCD_Ready”
    Open On-Chip Debugger 0.9.0 (2019-01-11)
    Licensed under GNU GPL v2
    For bug reports, read
    adapter speed: 3000 kHz
    Info : auto-selecting first available session transport “jtag”. To override use ‘transport select <transport>’.
    esp32 interrupt mask on
    Info : No device selected, using first device.
    Error: No J-Link device found.
    Do I have to change the script?
    where do I find it?
    #23630
    Thanks for the update. Unfortunately this one is tougher. It looks like OpenOCD does not know how to interface with the J-Trace version you have. Given that it uses a different driver with the regular Segger setup, it might not be backward-compatible (and hence compatible with OpenOCD) at all. You could try hacking our OpenOCD port to update the J-Link USB IDs, however this may not work if the internal protocol is different.
    As a quicker solution, please consider getting an FT2232-based debug probe (e.g. Olimex ARM-USB-OCD-H). Since ESP32 relies on OpenOCD anyway, there will be no usability difference between the more expensive J-Link probe and a cheaper FT2232-based one when debugging ESP32 devices.
