Sysprogs forums › Forums › VisualGDB › j-trace pro not recognized on usb
- This topic has 16 replies, 2 voices, and was last updated 7 years, 7 months ago by
December 27, 2018 at 21:31 #23172
wolpi
ParticipantHello,
I tried with V5.3 and 3.4p1:
I have j-link and a j-trace (connected via usb)
In the Debug settings, the j-link is recognised w/o problems under “Debug using”.
The j-trace does not show up.
On debug start, the j-trace can be choosen for debugging.
But j-trace features are not available (in 5.4p1).
Any ideas?
Regards
Bodo
Operating system is Windows10, Visual Studio 2017
December 28, 2018 at 03:46 #23173support
Please try updating the Segger debug plugin via Tools->VisualGDB->Manage VisualGDB Packages.
If this doesn’t help, please attach a screenshot of the settings page with the missing settings.
December 28, 2018 at 09:37 #23177wolpi
ParticipantHello,
thanks for the hint, it did the trick half way!
Now I can enable real-time tracing and everything on that side is working fine.
But still it does not recognise the j-trace as a valid debugger on usb (see attached picture)
(also it can use it by selecting it after debug start!)
It’s good to go for me now, I will buy VisualGDB!
If I can help fix the last issue, please let me know.
Thanks for the fast support and everybody a happy new Year!
Bodo
You must be logged in to view attached files.December 29, 2018 at 04:53 #23187support
Sorry for the confusion. The screenshot looks like J-Trace is actually recognized (it is shown as J-Link due to backward compatibility). Do you mean that you would expect it to be shown as “J-Trace”, not “J-Link”, or do you have both J-Trace and J-Link plugged in at the same time? In the latter case, what is the USB VID/PID of J-Trace?
December 29, 2018 at 06:31 #23188wolpi
In the screenshot i had plugged in both.
for j-Trace I got the following ID’s:
USB\VID_1366&PID_1020&REV_0100
Interesting enough, the j-link is listed under Universal Serial Bus controllers, while j-Trace is listed under Universal Serial Bus devices.
Regards
Bodo
December 31, 2018 at 00:08 #23203support
Thanks for checking this. It indeed looks like your J-Trace is using a USB ID that is not listed in the regular J-Link driver files and hence not being recognized by VisualGDB.
You can work around this by adding the following entry to %LOCALAPPDATA%\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.segger-dmsp\edp.xml: <UsbIdentity> <VID>1366</VID> <PID>0120</PID> </UsbIdentity>
Let us know if this works and we will update the file on our end.
December 31, 2018 at 09:09 #23219wolpi
ParticipantHello,
thanks for the quick reply in the middle of holiday season!
hope u had a nice X-mas!
The j-trace is now listed in the usb devices (as j-link).
Unfortunately it seems, segger has changed the complete interface structure.
The driver for the j-trace is listed in the USB devices, but starting the debugger gives the following error messages (see attachment).
Interesting enough, after it, the debug session starts normally.
You must be logged in to view attached files.December 31, 2018 at 09:24 #23224wolpi
ParticipantHere are some more hints:
Unlike j-link, the driver for j-trace is not the native segger driver, but the Microsoft WinUsb driver.
it’s listed in JLink.inf:
; 0x1020: J_LINK_WINUSB_DRV
so no J_LINK_SEGGER_DRV is loaded here.
I’m using: J-trace pro V2 Cortex (https://www.segger.com/products/debug-probes/j-trace/models/j-trace-cortex-arm/)
Current SW: 6.41a
I wish everybody a happy new Year!
You must be logged in to view attached files.January 3, 2019 at 21:16 #23242support
Happy New Year!
Thanks for the update. This indeed looks different from the J-Trace PRO unit we used to do our tests. Please try adding a separate ProgrammingInterface element for the J-Trace:
<ProgrammingInterface> <ID>com.sysprogs.debug.jlink.jtrace</ID> <Name>Segger J-Trace</Name> <Identities> <UsbIdentity> <VID>1366</VID> <PID>0120</PID> </UsbIdentity> </ProgrammingInterface>
This will let VisualGDB use the existing USB driver instead of trying to install the regular Segger driver.
January 3, 2019 at 22:48 #23245wolpi
we are getting nearer …
- it’s listed, but as unavailable
- there is still an error message when I start debugging
If I ignore it, debugging starts.
btw, I added the missing </Identities> tag ….
You must be logged in to view attached files.January 3, 2019 at 22:55 #23248support
Looks like your project properties still references the old device type (requiring the Segger driver). Please try reselecting the debug interface via Debug Settings (or creating a new project).
January 4, 2019 at 09:05 #23254wolpi
good news, I found the mistake!
I corrected it in the first try, but forgot to do it in the second.
now everything is working smoothly with j-trace!
here is the code:
<ProgrammingInterface> <ID>com.sysprogs.debug.jlink.jtrace</ID> <Name>Segger J-Trace</Name> <Identities> <UsbIdentity> <VID>1366</VID> <PID>1020</PID> </UsbIdentity> </Identities> </ProgrammingInterface>
Thanks for the fast help!
Regards
Bodo
January 5, 2019 at 05:02 #23263support
Thanks for confirming this. We will include the new device ID in the next release of our debug package for J-Link/J-Trace.
January 29, 2019 at 16:28 #23613wolpi
sorry to reopen this issue again …
but I just tried to debug an Arduino esp32 with the j-trace debugger, but it does not show up as an usb debugger in the VisualGDB settings ..
Same problem as we had above, but now with Arduino as project configuration.
Another xml to edit?? 🙂
Regards
Bodo
January 30, 2019 at 04:48 #23621support
Yes, the ESP8266/ESP32 devices use a separate debug method package (%LOCALAPPDATA%\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core). Also as the Segger GDB stub does not support the ESP8266 and ESP32 devices, they use OpenOCD that only works with the WinUSB driver. Please try adjusting the edp.xml and QuickSetup\interfaces.xml files to reflect your device ID. Feel free to post the necessary modifications here and we will update our packages accordingly.
