J-Link Debugger not good after VisualGDB Update
Sysprogs forums › Forums › VisualGDB › J-Link Debugger not good after VisualGDB Update
  • #12741
    Haqim
    I updated VisualGDB to newest version – which is awesome, great work!
    But with the debugging i had issues and now have them again.
    I work with an STM32 µC. I tried J-Link, it was super slow, i tried OpenOCD stuff, wich wasn’t good either, i tried again J-Link, but with using the JLinkARM.DLL it was super fast and very good to debug.
    With the new Version the interface is different and i cant directly use the JLinkARM.DLL again.
    Debugging is super slow again…
    Please help me get my debugging to work fast again 🙂
    regards
    Haqim.
    #12746
    We actually removed the direct mode as it was causing race conditions inside the J-Link DLL and sometimes showing incorrect data. It should normally not affect the normal debugging speed, only the speed of the real-time watch. Can you confirm that all debugging is now slow? Would you be able to share the gdb log with the timing labels so that we could see if we can work around this?
    #12747
    Haqim
    OK, race conditions i don’t want, also …
    I have around 5 seconds easily just for one step in code.
    But maybe some settings with my framing isn’t working right, but i don’t see a solution at the moment.
    I add some logs and a picture.
    #12771
    Sorry, the logs you attached unfortunately don’t show any timing. You can enable generation of timestamped logs via VisualGDB Project Properties -> Advanced GDB Settings -> Save all low-level interaction with GDB.
    Please also try using this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.14.1892.msi
    It resolves another issue related to Segger GDB stub and might solve the performance issues you are encountering as well.
