Issues with Project Properties
Sysprogs forums Forums VisualGDB Issues with Project Properties
  • #36866
    Colin Foster
    VisualGDB 5.6
    Visual Studio 2022
    I’ve been through the Create new Project wizard to create a Cygwin based project. This has been sucessful up to the point where I want to start changing “Makefile settings” in the Project Properties. In particular the “Make Command” setting and its sub-settings.
    Two things seems to be going wrong
    • the whole Makefile Settings view does not always reflect the actual settings stored in the .vgdbsettings file
    • I can’t change the Working Directory field away from $(BuildDir), neither using a direct paste of a path nor using the browse button.
    For example, if I paste in a path, click Apply, then Command changes to $(ToolchainMake), Arguments to $(ToolchainMakeArgs), and Working Directory to $(BuildDir), not matter what was in those fields before apply was pressed.
    In the .vgdbfile I still see custom settings
    <MakeCommandTemplate></div>
    <SkipWhenRunningCommandList>false</SkipWhenRunningCommandList></div>
    <Command>Make</Command></div>
    <Arguments>-j -k FORCE_REBUILD=off</Arguments></div>
    <WorkingDirectory>C:\Workspace\applications\NetOs App\D910</WorkingDirectory></div>
    <BackgroundMode xsi:nil=”true” /></div>
    </MakeCommandTemplate></div>
    When I build part of the output is showing that the cd still appears to be using $(BuildDir) irrespective of the settings in the .vgdbfile
    1>Executable: C:\cygwin420\bin\bash.exe
    1>Arguments: –login -c “cd /cygdrive/c/Workspace/applications/NetOS App VisualGDB && Make -j -k FORCE_REBUILD=off CONFIG=Debug”
    #36871
    #36873
    Colin Foster
    Sorry, I didn’t realise this was a paid for forum.
    If get the company to renew will I also be able to upgrade to version 6, or is that extra?
    • This reply was modified 6 months, 4 weeks ago by Colin Foster.
    #36875
    You can always post on the forum, and if anyone else decides help, they are always welcome to do so. We just post a standard reply with the renewal link, so others would know why we are not investigating it further.
    Either way, yes, the support and upgrades are always combined. You can generally use any VisualGDB version that was released before the support on your license expired. So renewing the license would always allow installing any version released before the renewed support period expires.
    #36882
    Colin Foster
    I believe we’ve paid for support. Can I get some help with the original post?
    #36889
    Thanks for renewing your support.
    This behavior is somewhat expected with the GNU Make projects. The regular Make project subsystem expects a particular Makefile layout, that places a few constraints on the project structure. One is that the build command should always run from the Makefile’s directory. The other one is that CFLAGS and other settings should be specified in a very rigid way, so VisualGDB can edit them using relatively simple regular expressions. You get the general idea by creating a new Make project, changing a few things via the GUI, and checking what files got changed as a result.
    If you have an existing big project with non-trivial Makefiles, we would advise importing it as an externally built project. It will remove all constraints on the command line, but things like include directories would require manually updating the Makefiles.
    A better (but more time-consuming option) would be upgrading to CMake. Unlike Make, CMake can produce machine-readable information about the project structure, so unless you do something really tricky (like custom macros), you can just select a target in Solution Explorer, change its properties, and VisualGDB will automatically find and edit the correct CMakeLists file defining that target.
