Sysprogs forums › Forums › VisualGDB › issue with updating to esp32 5.2 and new toolchain gcc 13.2
- This topic has 7 replies, 4 voices, and was last updated 1 year, 2 months ago by
maghsood.
March 5, 2024 at 23:42 #35402
milamber
ParticipantI had a project using esp32 and esp-idf 5.1 and the previous toolchain. I updated the toolchain and i got some build errors. Then I updated the esp-idf version to 5.2, visualgdb to 6 and the project to 5.2 but i got python errors. it was looking for python into C:\Users\george\AppData\Local\VisualGDB\Python3 while python was installed in C:\Users\george\AppData\Local\VisualGDB\Python-3.8.10 . After copying the directory into python3 i get an “ERROR: C:\Users\george\.espressif\espidf.constraints.v5.2.txt doesn’t exist. Perhaps you’ve forgotten to run the install scripts. Please check the installation guide for more information.” where is it getting this setting? i have installed espressif idf but it is in the C:\Espressif directory.
This is the batch file generated
REM Run “C:\Users\george\AppData\Local\VisualGDB\CMake\bin\cmake.exe ../../.. -G “Ninja” -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_MAKE_PROGRAM=C:/SysGCC/esp32/tools/ninja/1.11.1/ninja.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=0 -DIDF_TARGET=esp32″ in directory “xxxx/build/VisualGDB/Debug” on local computer
cd /d xxxx/build/VisualGDB/Debug
set LANG=en_US.UTF-8
set PATH=C:\Program Files\Git\cmd;C:\Espressif\python_env\\idf5.2_py3.8_env\Scripts;C:\Users\george\AppData\Local\VisualGDB\Python-3.8.10;C:\SysGCC\esp32\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin;C:\SysGCC\esp32\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin;C:\SysGCC\esp32\tools\esp32ulp-elf\2.35_20220830\esp32ulp-elf\bin;C:\SysGCC\esp32\tools\riscv32-esp-elf\esp-13.2.0_20230928\riscv32-esp-elf\bin;C:\SysGCC\esp32\tools\idf-exe\1.0.3;C:\SysGCC\esp32\tools\ccache\4.8\ccache-4.8-windows-x86_64;C:\SysGCC\esp32\tools\ninja\1.11.1;%PATH%
set IDF_TOOLS_PATH=
set IDF_PATH=C:\SysGCC\esp32\esp-idf\v5.2
set SYSPROGS_COMPONENTS_DIR=C:/SysGCC/esp32/esp-idf/SysprogsComponents
set IDF_GIT_DIR=C:\Program Files\Git\cmd
set IDF_PYTHON_DIR=C:\Users\george\AppData\Local\VisualGDB\Python-3.8.10
set IDF_PYTHON_ENV_PATH=C:\Espressif\python_env\\idf5.2_py3.8_env
set CMAKE_MAKE_PROGRAM=C:/SysGCC/esp32/tools/ninja/1.11.1/ninja.exe
“C:\Users\george\AppData\Local\VisualGDB\CMake\bin\cmake.exe” ../../.. -G “Ninja” -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_MAKE_PROGRAM=C:/SysGCC/esp32/tools/ninja/1.11.1/ninja.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=0 -DIDF_TARGET=esp32and then outpout
IDF_PATH is set to C:\SysGCC\esp32\esp-idf\v5.2
project_name is set to dev_wifi_station
— Found Git: C:/Program Files/Git/cmd/git.exe (found version “2.43.0.windows.1”)
— The C compiler identification is GNU 13.2.0
— The CXX compiler identification is GNU 13.2.0
— The ASM compiler identification is GNU
— Found assembler: C:/SysGCC/esp32/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe
— Detecting C compiler ABI info
— Detecting C compiler ABI info – done
— Check for working C compiler: C:/SysGCC/esp32/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe – skipped
— Detecting C compile features
— Detecting C compile features – done
— Detecting CXX compiler ABI info
— Detecting CXX compiler ABI info – done
— Check for working CXX compiler: C:/SysGCC/esp32/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-g++.exe – skipped
— Detecting CXX compile features
— Detecting CXX compile features – done
— Building ESP-IDF components for target esp32
— Checking Python dependencies… python C:/SysGCC/esp32/esp-idf/v5.2/tools/idf_tools.py check-python-dependencies
— pythonC:/SysGCC/esp32/esp-idf/v5.2/tools/idf_tools.pycheck-python-dependencies <– my debug info
— python C:/SysGCC/esp32/esp-idf/v5.2/tools/idf_tools.py check-python-dependencies
CMake Error at C:/SysGCC/esp32/esp-idf/v5.2/tools/cmake/build.cmake:368 (message):
Some Python dependencies must be installed. Check above message for
details.
C:/SysGCC/esp32/esp-idf/v5.2/tools/cmake/build.cmake:505 (__build_check_python)
C:/SysGCC/esp32/esp-idf/v5.2/tools/cmake/project.cmake:605 (idf_build_process)
CMakeLists.txt:43 (project)— Configuring incomplete, errors occurred!
Command exited with code 1
Executable: C:\Users\george\AppData\Local\VisualGDB\CMake\bin\cmake.exe
Arguments: ../../.. -G “Ninja” -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_MAKE_PROGRAM=C:/SysGCC/esp32/tools/ninja/1.11.1/ninja.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=0 -DIDF_TARGET=esp32
Command-line action failed========== Project Rebuild Summary ==========
fuelsensor.esp32 rebuilt in 00:03
========== Rebuild: 0 Succeeded, 1 Failed, 0 Skipped ==========why is it looking into the C:\Users\george\.espressif\ folder? in there 5.0 and 5.1 exist but not 5.2
March 6, 2024 at 08:16 #35403support
Please see the following page for more details: https://visualgdb.com/documentation/espidf/#python
March 6, 2024 at 15:40 #35405milamber
Participantfollowed the instructions but the problem remains.
- cleared the Python installations via Tools->Options->VisualGDB->General->Python Directory. (look at pic)
- I have deleted the python directories at %LOCALAPPDATA%\VisualGDB\Python*
- created a new project (blink) based on esp-idf 5.2 (see attchement) and clicked on the ‘get python’ button
this is the created the following directories
Volume in drive C has no label.
Volume Serial Number is 1028-E0A7Directory of C:\Users\george\AppData\Local\VisualGDB
03/06/2024 06:24 PM <DIR> .
02/20/2024 04:15 PM <DIR> ..
06/03/2023 04:02 PM 490 .clang-format
03/06/2024 01:14 AM 166 activation.key
06/03/2023 04:04 PM <DIR> AutoDownloadedSources
02/09/2024 12:15 AM <DIR> CMake
10/03/2023 10:03 PM <DIR> CppEngineDumps
12/03/2023 11:57 PM <DIR> EmbeddedDebugPackages
06/03/2023 03:26 PM 0 FindBSP.cmake
06/03/2023 03:26 PM 536 FindBSP.props
03/06/2024 01:14 AM 1,722 FindComponents.props
06/03/2023 03:26 PM 292 FindFrameworks.cmake
06/03/2023 03:26 PM 178 FindRemoteHost.props
03/06/2024 12:35 AM 1,143 FindToolchain.props
03/06/2024 02:35 AM 8,793 GUIPreferences.xml
03/06/2024 01:19 AM 4,110,696 PackageCatalog.xml
03/06/2024 06:24 PM <DIR> Python-3.8.10
06/03/2023 03:26 PM <DIR> QemuVMs
06/04/2023 12:43 AM <DIR> RemoteSourceCache
03/07/2023 02:00 PM <DIR> SharedFolders
03/06/2024 01:41 AM <DIR> temp
10 File(s) 4,124,016 bytes
11 Dir(s) 182,326,775,808 bytes freewhen i compile i get the same error
Running CMake: C:\Users\george\AppData\Local\VisualGDB\CMake\bin\cmake.exe ../../.. -G "Ninja" -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_MAKE_PROGRAM=C:/SysGCC/esp32/tools/ninja/1.11.1/ninja.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=0 -DIDF_TARGET=esp32— Found Git: C:/Program Files/Git/cmd/git.exe (found version “2.43.0.windows.1”)
— git rev-parse returned ‘fatal: not a git repository (or any of the parent directories): .git’
— Could not use ‘git describe’ to determine PROJECT_VER.
No Python at ‘C:\Users\george\AppData\Local\VisualGDB\Python3\python.exe’
CMake Error at C:/SysGCC/esp32/esp-idf/v5.2/tools/cmake/build.cmake:371 (message):
Failed to run Python dependency check. Python: python, Error: 103
CMakeLists.txt:6 (project)System.Exception: CMake exited with code 1
at a4.b(a a, Object b)it is looking for python C:/SysGCC/esp32/esp-idf/v5.2/tools/idf_tools.py check-python-dependencies
where obviously there is none. so i copy the Python-3.8.10 directory into Python3 and the build fails in the same way
Run “C:\Users\george\AppData\Local\VisualGDB\CMake\bin\cmake.exe ../../.. -G “Ninja” -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_MAKE_PROGRAM=C:/SysGCC/esp32/tools/ninja/1.11.1/ninja.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=0 -DIDF_TARGET=esp32″ in directory “C:\d\FS\EmbeddedProject1\EmbeddedProject1/build/VisualGDB/Debug” on local computer
details.
CMakeLists.txt:6 (project)— Configuring incomplete, errors occurred!
Directory: C:\d\FS\EmbeddedProject1\EmbeddedProject1/build/VisualGDB/Debug
Command-line action failed========== Project Build Summary ==========
EmbeddedProject1 built in 00:03
========== Build: 0 Succeeded, 1 Failed, 0 Skipped ==========it is looking to find the C:\Users\george\.espressif\espidf.constraints.v5.2.txt file which doesnt exist, is the the directory where espresiff keeps in vscode installation?
You must be logged in to view attached files.March 6, 2024 at 15:55 #35408support
Please do not manually copy any directories without understanding what causes the underlying problem. This only entangles the issue further and makes it harder to troubleshoot.
You can try exporting the ESP-IDF configuration command used by VisualGDB to a batch file as shown here. If the batch file shows incorrect IDF_PYTHON_ENV_PATH value, please let us know and we will look into it.
If the value looks correct, and ESP-IDF still doesn’t work, it could be a bug in ESP-IDF. Please consider reporting it to Espressif. If they suggest a configuration command line that fixes the problem, we can help you configure VisualGDB to use it instead.
March 6, 2024 at 21:09 #35409milamber
Participanti did that in my first post . it is the first thing in the post. i found where espressif for vscode installs by default in 5.2 (C:\Users\george\esp\v5.2.1\esp-idf) and copied espidf.constraints.v5.2.txt to where visualgdb expected it (where espressif installed until 5.1 C:\Users\george\.espressif) and the problem was solved.
i understand its a hack but the documentation provided didnt help solve.
I can delete everything and try again but i have done it a few times already with the same result. it seems that the installation of espressif somehow affects visualgdb although i thought that the 2 were independent.
I would be happy to troubleshoot if you want me to.
March 6, 2024 at 21:18 #35410milamber
Participantit seems there is a double \\ after
python_envin the batch fileset IDF_PYTHON_ENV_PATH=C:\Espressif\python_env\\idf5.2_py3.8_envMarch 7, 2024 at 12:50 #35411milamber
Participantapparently when i execute
Constraint file: C:\Users\george\.espressif\espidf.constraints.v5.2.txt
Requirement files:
- C:\SysGCC\esp32\esp-idf\v5.2\tools\requirements\requirements.core.txt
Python being checked: C:\Espressif\python_env\idf5.2_py3.8_env\Scripts\python.exe
Python requirements are satisfied.it looks into this file
C:\Users\george\.espressif\espidf.constraints.v5.2.txt why is that in 5.2?January 20, 2025 at 04:11 #36307maghsood
ParticipantThe root cause of this problem lies in the build process when
build.cmakechecks Python dependencies using the line:
execute_process(COMMAND "${python}" "${idf_path}/tools/idf_tools.py" "check-python-dependencies").During this check, the
idf_tools.pyscript assumes the.espressiffolder and its required files (likeespidf.constraints.v5.3.txt) are in the default user directory (e.g.,C:\Users\[YourUsername]\.espressif). If this folder or file is missing, the build fails. This happens because the script defaults to looking in the user folder, regardless of where the actual ESP-IDF files are installed.Solution
- Locate the file
espidf.constraints.v5.3.txtinC:\Espressif\espidf.constraints.v5.3.txtor in the tools folder of your ESP-IDF installation. - Copy the file to the
.espressifdirectory under your user folder (e.g.,C:\Users\[YourUsername]\.espressif). - Right-click on your project in Visual Studio, select “Clean Project,” and the error should be resolved.
I tested it worked forme, Visualstudio 2019 and 2022
This reply was modified 1 year, 2 months ago by
maghsood.
