Sysprogs forums › Forums › VisualGDB › Issue with ESP-IDF project and flash burning
- This topic has 3 replies, 2 voices, and was last updated 7 years, 9 months ago by
July 11, 2018 at 18:12 #21345
dedvalson
I have an annoyance that I wonder if there is a way around. When I try to start a new debug session, the flash burn fails every other try (exactly every other one).
What is interesting though is that I do not have this issue when I set “Debug Using” to “ESP32 DevKit”
I do have this issue when using my hardware. In this case I choose “OpenOCD, and interface/ftdi/tumpa.cfg”
But what is interesting is that my hardware (when connected to the tumpa card) is identical to what is in the ESP32 DevKit. But of course the chip in the devkit has a different USB ID.
Is there a way for me to use the method that works with the ESP32 DevKit on what should be identical hardware with the tumpa board?
Don
July 11, 2018 at 23:50 #21347support
If the problem only occurs on your board, but not on the reference board, it is likely caused by wiring issues (e.g. cross-talk, wrong reset connection, etc.). Generally if the problem cannot be reliably reproduced on any of the boards mentioned in our tutorials, we won’t be able to offer much help as a part of our regular product support. That said, feel free to attach the error log you are getting from OpenOCD. If this is something we have seen before, we might be able to at least suggest the direction for further investigation.
July 12, 2018 at 14:17 #21354dedvalson
I get the same error on the reference board if I use OpenOCD and interface/ftdi/devkitj_f1. But I don’t get it if I choose USB Devices and ESP32 DevKit.
I have attached two screen shots (I can’t see how to make them display inline. One shows the configuration that works on the reference board, the other shows the configuration that fails every other time on the reference board.
The text of the error is as follows:
VisualGDB is licensed to Don Edvalson at CoralVue Industries
-gdb-version
=thread-group-added,id="i1"
~"GNU gdb (GDB) 7.10\n"
~"Copyright (C) 2015 Free Software Foundation, Inc.\n"
~"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \"show copying\"\nand \"show warranty\" for details.\n"
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
~"This GDB was configured as \"--host=i686-pc-mingw32 --target=xtensa-esp32-elf\".\nType \"show configuration\" for configuration details."
This GDB was configured as "--host=i686-pc-mingw32 --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
~"\nFor bug reporting instructions, please see:\n"
~"<http://www.gnu.org/software/gdb/bugs/>.\n"
~"Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n"
~"For help, type \"help\".\n"
~"Type \"apropos word\" to search for commands related to \"word\"...\n"
~"Reading symbols from c:/Users/Don/source/CoralVue/Atlas/Debug/Atlas.elf..."
~"done.\n"
~"Type \"apropos word\" to search for commands related to \"word\".\n"
^done
-list-features
^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info","language-option","info-gdb-mi-command","undefined-command-error-code","exec-run-start-option"]
^error,msg="No symbol \"disassembly\" in current context."
-gdb-set print demangle off
^done
set remotetimeout 60
&"set remotetimeout 60\n"
=cmd-param-changed,param="remotetimeout",value="60"
^done
target remote :52349
&"target remote :52349\n"
~"Remote debugging using :52349\n"
=thread-group-started,id="i1",pid="42000"
=thread-created,id="1",group-id="i1"
~"invoke_abort () at /esp-idf/master/components/esp32/panic.c:137\n"
&"137\t/esp-idf/master/components/esp32/panic.c: No such file or directory.\n"
*stopped,frame={addr="0x4008f10f",func="invoke_abort",args=[],file="/esp-idf/master/components/esp32/panic.c",fullname="/esp-idf/master/components/esp32/panic.c",line="137"},thread-id="1",stopped-threads="all"
^done
info shared
&"info shared\n"
~"No shared libraries loaded at this time.\n"
^done
mon reset halt
&"mon reset halt\n"
@"JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n"
@"JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n"
@"esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).\n"
@"esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).\n"
@"Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000 \n"
@"esp32: target state: halted\n"
@"esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).\n"
@"Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400 \n"
^done
mon program_esp32 "c:/Users/Don/source/CoralVue/Atlas/Debug/bootloader/bootloader.bin" 0x1000
&"mon program_esp32 \"c:/Users/Don/source/CoralVue/Atlas/Debug/bootloader/bootloader.bin\" 0x1000\n"
@"** Programming Started **\n"
@"auto erase enabled\n"
@"no flash bank found for address 1000\n"
@"wrote 0 bytes from file c:/Users/Don/source/CoralVue/Atlas/Debug/bootloader/bootloader.bin in 0.000000s (nan KiB/s)\n"
@"** Programming Finished **\n"
^done
-target-disconnect
=thread-group-exited,id="i1"
^done
-gdb-exit
^exitAttachments:
You must be logged in to view attached files.July 12, 2018 at 20:31 #21359support
Thanks for clarifying this. Please try clicking the “test connection” button in both cases, copy the OpenOCD command line shown in the test window and then compare the working command line with non-working one. Then please try running OpenOCD manually to determine a specific flag that causes the issue.
