Is it possible add Cortex A9 support ?
Sysprogs forums Forums VisualGDB Is it possible add Cortex A9 support ?
  • #26513
    DASM
    Or any of A series? Is there examples how to?
    #26521
    The Cortex-A devices are typically used together with Linux and hence require a special Linux toolchain built for the exact distribution/configuration that is running on the target.
    We provide toolchains for the most commonly used Cortex-A boards (e.g. Raspberry Pi, Beaglebone). If you are using a different board, please check the board vendor for a cross-toolchain.
    If you are looking for a barebone environment (without Linux), please try creating a project manually as shown in this tutorial: https://visualgdb.com/tutorials/arm/legacy/
    #26524
    DASM
    Thanks for reply. Yes, it is baremetal no OS app (Beaglebone black). I will try setip manually, ok!
    • This reply was modified 6 years, 10 months ago by DASM.
