Intellisense – Unrecognized type H file inside H file
Sysprogs forums › Forums › VisualGDB › Intellisense – Unrecognized type H file inside H file
  • #35460
    BoazMegg
    STM32 project (Mx cube), C language.
    An H file that has structs defined with a type defined on another H file.
    Intellisense shows ‘unrecognized type’ although both files are then included by the C (or another H file).
    The only solution is the re-include the first file on the second one.
    Is there another option so intellisense won’t show such errors/warnings (i.e. will show the type as defined as it is defined on the project)?
    #35461
    Normally the first header file should just include the second one. As long as both header files have a #pragma once, it should work just fine.
    Another option would be to explicitly open the header file in a context of a .c/.cpp file that includes both of them in the correct order. You can do it via the navigation bar in the new VisualGDB 6.0.
