Intellisense for ESP32 project
Sysprogs forums Forums VisualGDB Intellisense for ESP32 project
  • #32639
    orbitcoms
    Hi
    I have a visual gdb project in Visual Studio 2022 that is running and compiling ok but the intellisense does not seem to be picking up and highlighting keywords from included file.
    ie: built-in keywords like variable types, return, void etc are highlighted but not library function names like ESP_LOGI, xSemaphore, TimerHandle_t etc. Also not seeing the autocomplete suggestions when I start typing the function.
    The VisualGDB settings are set to “Advanced  Clang Intellisense” , which is only one supported by look of it.
    The project is using GCC8.2 and esp-idf 4.4.1
    UPDATE: When I close and restart Visual studio, the intellisense starts working again.
    Anyone have an idea what would cause it to stop during code writing and come back on reboot?
    • This topic was modified 4 years, 4 months ago by orbitcoms.
    #32660
    Unfortunately, it is hard to suggest anything specific based on the description you provided.
    Please provide complete and detailed steps to reproduce the issue as described below:
    1. The steps should begin with launching Visual Studio. They should include every step necessary to create the project from scratch and reproduce the issue.
    2. Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch.
    3. The steps should include uncropped screenshots of all wizard pages, VisualGDB Project Properties pages and any other GUI involved in reproducing the problem. This is critical for us to be able to reproduce the problem on our side.
