Installaion failed
Sysprogs forums › Forums › WinCDEmu › Installaion failed
  • #521
    scout12
    Hello I am trying to install WinCDEmu on a machine right after the unattended section of sysprep in Windows 7 x64. I get a popup that says “Error: Installation Failed” and the task below says updating registry. Below are the commands I’m using to install.
    certutil -addstore -f “TrustedPublisher” WinEmu.cer
    WinCDEmu-3.6.exe /UNATTENDED
    #2270
    Yes, I have the same effect with Microsoft SCCM (agent is only x86) and win7 x64 clients.
    – We using schematic scripts (install-sccm.cmd and uninstall-sccm.cmd) for the install and uninstall.
    – the same two lines in test environment (start a x86 CMD with local admin rights and then start the install-sccm.cmd script), install works fine within round about 5 secs.
    – this ok-tested script doesn’t works fine when started with the sccm agent (SYSTEM-rights). the certificate will be installed, but the winCDEmu-3.6.exe /UNATTENDED freeze after file copy. In the taskmanager you can see the endless “running” process winCDEmu-3.6.exe /UNATTENDED as SYSTEM
    The same script, only two versions to run.
    – in a x86 CMD with local admin rights in works fine (our final check before we set the script productive in SCCM)
    – startet from an x86 agent with SYSTEM rights it doesn’t work
    I have no more ideas 🙁
