I’m having some instabilities with a cmake imported project (Embedded Project > Existing project from command line > CMake).
My targets do not seem to regenerate automatically when I edit and save my CMakeLists.txt. I did not see a way to regenerate manually.
So I cleaned and rebuilded my target, but the build seems to hang :
------ Build started: Project: EmbeddedProject1, Configuration: Debug VisualGDB ------
Reconfiguring project due to missing Makefile...
If I re-try to build, it fails with
VisualGDB version: 5.4.112.3309
------------------ System.Runtime.InteropServices.COMException ------------------
System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED))
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at Microsoft.VisualStudio.ErrorHandler.ThrowOnFailure(Int32 hr, Int32[] expectedHRFailure)
at by1.r1(Object b, jw a)
at hl2.w(Target d, g42 c, Boolean a, Boolean b)
at ga2.e.e_4(w42 a, Object b)
at q52.z.Exec(Guid& b, UInt32 d, UInt32 c, IntPtr e, IntPtr a)
I also have numerous deprecation warnings :
CMake Deprecation Warning:
The 'cmake-server(7)' is deprecated. Please port clients to use the
'cmake-file-api(7)' instead.
