Importing ATSAMD SVD register file
Sysprogs forums Forums VisualGDB Importing ATSAMD SVD register file
  • #28641
    thm
    Trying to import the following SVD file:
    https://raw.githubusercontent.com/microsoft/uf2-samdx1/master/lib/samd51/svd/ATSAMD51G18A.svd
    The error received is “Object reference not set to an instance of an object”. Tried a few other SVD’s from SAMD chips and the result is the same.
    VisualGDB version: 5.5.7.3666
    ------------------ System.NullReferenceException ------------------
    at u21.f(XmlElement a, List1 e, String b, UInt32 d, Nullable1 c)
    at u21.i(String a, String b)
    at VisualGDB.Add_In.Tool_Windows.WPF.HardwareRegisters.HardwareRegistersToolControl.ControllerImpl.ImportRegisterDefinition(Boolean isAuxiliary)
    trace=[u21.f:984, u21.i:295, VisualGDB.Add_In.Tool_Windows.WPF.HardwareRegisters.HardwareRegistersToolControl+ControllerImpl.ImportRegisterDefinition:201]
    Importing the basic example XML file works OK, so it seems to be something specific to this SVD format.
    Any advice appreciated, thank you.
    • This topic was modified 5 years, 9 months ago by thm.
    #28643
    No problem, we have reproduced and fixed the issue in this build: VisualGDB-5.5.7.3700.msi
    #28647
    thm
    Incredible, thank you for the fast fix, its working well.
