Imported project structure
Sysprogs forums Forums VisualGDB Imported project structure
  • #6238
    sashoks34
    I’d like to import a linux project that I compile in eclipse.
    My project structure on linux machine is as following :
    /MainSolutionDir
    —workspace
    ——project1
    ——project2
    —sources
    ——project1
    ——project2
    The directories under workspace include object,  binaries, makefile and project xml.
    What directory should I pass to the Import wizard in order to import project1, for example?
    • This topic was modified 11 years ago by sashoks34.
    #6256
    The easiest solution would be to pass the directory of the main makefile and then add further files to your project via <right click in Solution Explorer>->add->Add folder recursively.
