IDF_PATH in CMakeList
Sysprogs forums Forums VisualGDB IDF_PATH in CMakeList
  • #34513
    mattia
    I recently switched from IDF 5.0_dev to IDF 5.1 release. However, the toolchain now doesn’t work anymore, with CmakeList.txt that gives me an error in the line “include($ENV{IDF_PATH}/tools/cmake/project.cmake)”
    In particular, IDF_PATH still points to the old IDF5.0_Dev and not the new one. Is there a way to make the CmakeList.txt point to this new project? Where is the variable IDF_PATH stored in my project?
    Thank you,
    Mattia
    #34514
    #34537
    mattia
    Ok, I just renewed.
    #34539
    Thanks for renewing your license.
    VisualGDB sets the IDF_PATH value based on the toolchain and ESP-IDF version selected in VisualGDB Project Properties -> ESP-IDF Project.
    If your existing project stopped working after switching to a new toolchain, we would advise creating a new project for the new toolchain/ESP-IDF, making sure it works, and then using a diffing tool to compare the settings files (.vgdbcmake, sdkconfig, etc.) between the 2 projects.
    You can also find detailed overview of the ESP-IDF project structure and troubleshooting tips here: https://visualgdb.com/documentation/espidf/
