i586-poky-linux-gcc.exe: error: CreateProcess: No such file or directory
Sysprogs forums › Forums › VisualGDB › i586-poky-linux-gcc.exe: error: CreateProcess: No such file or directory
  • #11093
    christoph.p
    I’ve installed Visual Studio 2017, und the newest VisualGDB. Now I try to compile an
    older project, but I get always:
    Tool arguments: -c “C:\Users\Christoph\AppData\Local\Temp\/VisualGDB_ToolchainTestProgram.c” -o “C:\Users\Christoph\AppData\Local\Temp\/VisualGDB_ToolchainTestProgram.o” -ggdb -ffunction-sections
    #11094
    christoph.p
    Please help. I have to get it to work fast…
    #11095
    This looks like a corrupt toolchain. Is it one of the toolchains shipped with VisualGDB?
    #11096
    christoph.p
    Thank you very much for your answer!
    No. As the Tutorial in (https://visualgdb.com/tutorials/linux/edison/) doesn’t work any more (the Intel Edison
    Installer doesn’t offer any development environment any more), I have extracted the toolchain somewhere out
    of the archives of here: https://downloadcenter.intel.com/de/product/84574/Intel-Edison-Board-for-Arduino-
    On my previous PC, the toolchain I used worked well. But now I get this strange error. I read in the net that
    with Mingw it’s often a PATH environment var problem.
    Although on my previous PC there weren’t any paths set in “PATH” to any Edison / GDB related directories. Could
    this be the problem I have now?
    The things that have changed from the previous machine to now is Visual Studio (now 2017 and not 2015 any more)
    and the Visual GDB Version.
    As you talked about a VisualGDB shipped toolchain. Can I get a VisualGDB shipped toolchain for the Intel Edison?
    That would be very nice because at the moment I have to get it to work in a dubious indirect way.
    Thanks for you fast help (I hope it’s going on…)
    • This reply was modified 9 years, 5 months ago by christoph.p.
    #11099
    Thanks for the explanation. As Intel Edison is not as popular as Raspberry Pi and other modern boards, we don’t ship a separate toolchain for it (the only other option would be to build a custom toolchain under our toolchain building service that usually costs EUR 1000 per toolchain).
    Some GCC toolchains are configured in a way that requires their location to be stored in the registry, so just extracting the files for such a toolchain won’t work. We would recommend checking the archives and 3rd-party sites for a usable toolchain; if the toolchain itself is broken and does not work, VisualGDB unfortunately cannot fix this.
    #11106
    christoph.p
    I’ve downloaded “Cross Compiler Toolchain for Intel® Edison Maker Board” from here: https://downloadcenter.intel.com/download/24472/Cross-Compiler-Toolchain-for-Intel-Edison-Maker-Board?product=86928
    My sysroots is “–sysroot=C:\Users\Christoph\Downloads\edison-toolchain-20150120-windows\i686\pokysdk\usr\bin\i586-poky-linux”
    where the downloaded archive is extracted to “C:\Users\Christoph\Downloads\edison-toolchain-20150120-windows”
    I’ve not changed anything else on the sample projekt. I think there is some kind of problem with the surrounding environmen (windows 10 / visual studio / visualGDB)?
    The test.cpp
    <p style=”padding-left: 30px;”>#include <iostream>
    using namespace std;
    int main(int argc, char *argv[])
        char sz[] = “Hello, World!”;    //Hover mouse over “sz” while debugging to see its contents
        cout << sz << endl;    //<================= Put a breakpoint here
        return 0;
    }</p>
    Thats my makefile:
    <p style=”padding-left: 30px;”>#Generated by VisualGDB project wizard.
    #Note: VisualGDB will automatically update this file when you add new sources to the project.
    #All other changes you make in this file will be preserved.
    #Visit http://visualgdb.com/makefiles for more details
    #VisualGDB: AutoSourceFiles #
    TARGETNAME := Test
    #TARGETTYPE can be APP, STATIC or SHARED
    TARGETTYPE := APP
    to_lowercase = $(subst A,a,$(subst B,b,$(subst C,c,$(subst D,d,$(subst E,e,$(subst F,f,$(subst G,g,$(subst H,h,$(subst I,i,$(subst J,j,$(subst K,k,$(subst L,l,$(subst M,m,$(subst N,n,$(subst O,o,$(subst P,p,$(subst Q,q,$(subst R,r,$(subst S,s,$(subst T,t,$(subst U,u,$(subst V,v,$(subst W,w,$(subst X,x,$(subst Y,y,$(subst Z,z,$1))))))))))))))))))))))))))
    CONFIG ?= DEBUG
    CONFIGURATION_FLAGS_FILE := $(call to_lowercase,$(CONFIG)).mak
    include $(CONFIGURATION_FLAGS_FILE)
    #LINKER_SCRIPT defined inside the configuration file (e.g. debug.mak) should override any linker scripts defined in shared .mak files
    CONFIGURATION_LINKER_SCRIPT := $(LINKER_SCRIPT)
    include $(ADDITIONAL_MAKE_FILES)
    ifneq ($(CONFIGURATION_LINKER_SCRIPT),)
    LINKER_SCRIPT := $(CONFIGURATION_LINKER_SCRIPT)
    endif
    ifneq ($(LINKER_SCRIPT),)
    LDFLAGS += -T$(LINKER_SCRIPT)
    endif
    ifeq ($(BINARYDIR),)
    error:
    $(error Invalid configuration, please check your inputs)
    endif
    SOURCEFILES := Test.cpp
    EXTERNAL_LIBS :=
    EXTERNAL_LIBS_COPIED := $(foreach lib, $(EXTERNAL_LIBS),$(BINARYDIR)/$(notdir $(lib)))
    CFLAGS += $(COMMONFLAGS)
    CXXFLAGS += $(COMMONFLAGS)
    ASFLAGS += $(COMMONFLAGS)
    LDFLAGS += $(COMMONFLAGS)
    CFLAGS += $(addprefix -I,$(INCLUDE_DIRS))
    CXXFLAGS += $(addprefix -I,$(INCLUDE_DIRS))
    CFLAGS += $(addprefix -D,$(PREPROCESSOR_MACROS))
    CXXFLAGS += $(addprefix -D,$(PREPROCESSOR_MACROS))
    ASFLAGS += $(addprefix -D,$(PREPROCESSOR_MACROS))
    CXXFLAGS += $(addprefix -framework ,$(MACOS_FRAMEWORKS))
    CFLAGS += $(addprefix -framework ,$(MACOS_FRAMEWORKS))
    LDFLAGS += $(addprefix -framework ,$(MACOS_FRAMEWORKS))
    LDFLAGS += $(addprefix -L,$(LIBRARY_DIRS))
    ifeq ($(GENERATE_MAP_FILE),1)
    LDFLAGS += -Wl,-Map=$(BINARYDIR)/$(basename $(TARGETNAME)).map
    endif
    LIBRARY_LDFLAGS = $(addprefix -l,$(LIBRARY_NAMES))
    ifeq ($(IS_LINUX_PROJECT),1)
    RPATH_PREFIX := -Wl,–rpath=’$$ORIGIN/../
    LIBRARY_LDFLAGS += $(EXTERNAL_LIBS)
    LIBRARY_LDFLAGS += -Wl,–rpath=’$$ORIGIN’
    LIBRARY_LDFLAGS += $(addsuffix ‘,$(addprefix $(RPATH_PREFIX),$(dir $(EXTERNAL_LIBS))))
    ifeq ($(TARGETTYPE),SHARED)
    CFLAGS += -fPIC
    CXXFLAGS += -fPIC
    ASFLAGS += -fPIC
    LIBRARY_LDFLAGS += -Wl,-soname,$(TARGETNAME)
    endif
    ifneq ($(LINUX_PACKAGES),)
    PACKAGE_CFLAGS := $(foreach pkg,$(LINUX_PACKAGES),$(shell pkg-config –cflags $(pkg)))
    PACKAGE_LDFLAGS := $(foreach pkg,$(LINUX_PACKAGES),$(shell pkg-config –libs $(pkg)))
    CFLAGS += $(PACKAGE_CFLAGS)
    CXXFLAGS += $(PACKAGE_CFLAGS)
    LIBRARY_LDFLAGS += $(PACKAGE_LDFLAGS)
    endif
    else
    endif
    LIBRARY_LDFLAGS += $(ADDITIONAL_LINKER_INPUTS)
    all_make_files := $(firstword $(MAKEFILE_LIST)) $(CONFIGURATION_FLAGS_FILE) $(ADDITIONAL_MAKE_FILES)
    ifeq ($(STARTUPFILES),)
    all_source_files := $(SOURCEFILES)
    else
    all_source_files := $(STARTUPFILES) $(filter-out $(STARTUPFILES),$(SOURCEFILES))
    endif
    source_obj1 := $(all_source_files:.cpp=.o)
    source_obj2 := $(source_obj1:.c=.o)
    source_obj3 := $(source_obj2:.s=.o)
    source_obj4 := $(source_obj3:.S=.o)
    source_obj5 := $(source_obj4:.cc=.o)
    source_objs := $(source_obj5:.cxx=.o)
    all_objs := $(addprefix $(BINARYDIR)/, $(notdir $(source_objs)))
    PRIMARY_OUTPUTS :=
    ifeq ($(GENERATE_BIN_FILE),1)
    PRIMARY_OUTPUTS += $(BINARYDIR)/$(basename $(TARGETNAME)).bin
    endif
    ifeq ($(GENERATE_IHEX_FILE),1)
    PRIMARY_OUTPUTS += $(BINARYDIR)/$(basename $(TARGETNAME)).ihex
    endif
    ifeq ($(PRIMARY_OUTPUTS),)
    PRIMARY_OUTPUTS := $(BINARYDIR)/$(TARGETNAME)
    endif
    all: $(PRIMARY_OUTPUTS)
    $(BINARYDIR)/$(basename $(TARGETNAME)).bin: $(BINARYDIR)/$(TARGETNAME)
    $(OBJCOPY) -O binary $< $@
    $(BINARYDIR)/$(basename $(TARGETNAME)).ihex: $(BINARYDIR)/$(TARGETNAME)
    $(OBJCOPY) -O ihex $< $@
    $(BINARYDIR)/$(TARGETNAME): $(LINKER_SCRIPT)
    endif
    ifeq ($(TARGETTYPE),APP)
    $(BINARYDIR)/$(TARGETNAME): $(all_objs) $(EXTERNAL_LIBS)
    $(LD) -o $@ $(LDFLAGS) $(START_GROUP) $(all_objs) $(LIBRARY_LDFLAGS) $(END_GROUP)
    endif
    $(LD) -shared -o $@ $(LDFLAGS) $(START_GROUP) $(all_objs) $(LIBRARY_LDFLAGS) $(END_GROUP)
    endif
    ifeq ($(TARGETTYPE),STATIC)
    $(AR) -r $@ $^
    endif
    -include $(all_objs:.o=.dep)
    clean:
    ifeq ($(USE_DEL_TO_CLEAN),1)
    cmd /C del /S /Q $(BINARYDIR)
    else
    rm -rf $(BINARYDIR)
    endif
    $(BINARYDIR):
    mkdir $(BINARYDIR)
    #VisualGDB: FileSpecificTemplates # $(BINARYDIR)/%.o : %.cpp $(all_make_files) |$(BINARYDIR)
    $(CXX) $(CXXFLAGS) -c $< -o $@ -MD -MF $(@:.o=.dep)
    $(BINARYDIR)/%.o : %.c $(all_make_files) |$(BINARYDIR)
    $(CC) $(CFLAGS) -c $< -o $@ -MD -MF $(@:.o=.dep)
    $(BINARYDIR)/%.o : %.S $(all_make_files) |$(BINARYDIR)
    $(CC) $(CFLAGS) $(ASFLAGS) -c $< -o $@ -MD -MF $(@:.o=.dep)
    $(BINARYDIR)/%.o : %.s $(all_make_files) |$(BINARYDIR)
    $(BINARYDIR)/%.o : %.cc $(all_make_files) |$(BINARYDIR)
    $(CC) $(CFLAGS) $(CXXFLAGS) -c $< -o $@ -MD -MF $(@:.o=.dep)
    $(BINARYDIR)/%.o : %.cxx $(all_make_files) |$(BINARYDIR)
    #VisualGDB: GeneratedRules #
    </p>
    #11108
    christoph.p
    Ok. got it with a new downloaded toolchain from intel. Because the directory structure changed, I hat such problems…
    #11116
    Good to hear it works. If you encounter any further issues, let us know.
