Hi Support,
This is probably not the right forum to ask this, but I thought I’d try. I have some legacy code that throws an exception. However, when it is thrown the c++ library is calling std::terminate(). That usually means there is no matching catch. I’ve used all sorts of catch parameters, including catch(…) but all the same result. I’ve tried catching the exception in the same function that throws it and using the -fexceptions switch.
Has anyone got any suggestions?
Cheers
David
