I cannot run program flash memory
Sysprogs forums Forums VisualGDB I cannot run program flash memory
  • #36161
    ruggero.bandera
    I cannot run program flash memory or Launch ESP-IDF Monitor I always got this error
    VisualGDB version: 6.0.104.5220
    —————— System.ArrayTypeMismatchException ——————
    System.ArrayTypeMismatchException: Attempted to access an element as a type incompatible with the array.
    at System.ThrowHelper.ThrowArrayTypeMismatchException()
    at Microsoft.VisualStudio.CommonIDE.Solutions.BuildManager.SolutionBuildManager.HrUpdateProjects(vsBuildScope buildScope, SLNUPDACTION dwUpdateActions, UInt32 cProjs, IVsHierarchy[] rgpHierProjs, __VSDBGLAUNCHFLAGS grfLaunch, Boolean fSuppressUI, IVsSlnConfiguration pSlnCfg, Boolean alwaysRespectSlnCfgCheckBoxes)
    at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
    at w4.q2(Object b, iu1 a)
    at wd1.d(dh1 b, vg1 a)
    at dh3.b.Exec(Guid& d, UInt32 a, UInt32 b, IntPtr e, IntPtr c)
    trace=[System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal:-1, w4.q2:116, wd1.d:404, dh3+b.Exec:438]
    #36167
    Please make sure you are using the latest VisualGDB 6.0R5. You can download it here: https://visualgdb.com/download/
