I saw some people here wanted to use the latest gcc for C++ 11/14. Here’s what I’m doing:
1.) In VisualGDB, setup your project like you would if you were going to cross compile for RP or Beagle Bone
2.) Download the Linaro tool chain here: http://www.linaro.org/downloads/ linaro-toolchain-binaries 4.9 (little-endian)
3.) Install Linaro in C:SysGCClinaro
4.) Edit your debug/release.mak files to look like this (verify the Linaro installed to correct path):
#Toolchain
CC := C:/SysGCC/linaro/bin/arm-linux-gnueabihf-gcc.exe
CXX := C:/SysGCC/linaro/bin/arm-linux-gnueabihf-g++.exe
LD := $(CXX)
AR := C:/SysGCC/linaro/bin/arm-linux-gnueabihf-ar.exe
OBJCOPY := C:/SysGCC/linaro/bin/arm-linux-gnueabihf-objcopy.exe
Of course make sure to use the -std=c++1y or -std=c++11 flags to use the C++ features in GCC.
Intellisense is kind of broken here because VS defines _cplusplus as 199711L. Please note I have not done RP, but this does work on BeagleBone and ODroid.
Hope this helps
-Jer
