So for protobuf, you start with a *.proto file, which you have to first call protoc to generate the c and header files, then you have to compile with g++. How can I automate this with VisualGDB to a remote Linux server?
protoc -I=. –cpp_out=. Example.proto
g++ -c Example.pb.cc
… repeat for each proto file.
g++ -o Messages.a Example1.pb.o Example2.pb.o …
This topic was modified 8 years, 5 months ago by LakeWorthB.
If you are using a Custom edition or higher, you can simply add a custom pre-build action.
Another option would be to add a custom Makefile target or a cutsom MSBuild target. We don’t have an example specific to protobuf, however you can try following our tutorial for building Qt projects with MSBuild for a detailed example on creating custom MSBuild rules and targets.
