Sysprogs forums › Forums › VisualGDB › How to use supplied .ioc file when importing CubeMx project?
- This topic has 3 replies, 2 voices, and was last updated 3 years, 4 months ago by
November 10, 2022 at 06:39 #33415
Gast
ParticipantUsing the STM32CubeMx Project Wizard, VisualGDB will open the STM32 CubeMX tool.
At this step, how can I use the .ioc file provided by the project to be importet?
Configuring the target by hand at this step would be unnecessarily painful.
Loading the provided ioc file at this step does not work (the empty ioc file will nevertheless be imported upon closing the STM32CubeMx window)
November 10, 2022 at 08:41 #33424support
KeymasterThanks for confirming your license. The .ioc files contain settings for the STM32CubeMX generator and do not directly reference any source files/build settings or anything else that could be imported.
In order to import them into VisualGDB, you would first need to open them in STM32CubeMX, then generate an STM32CubeIDE project, and finally import the generated STM32CubeIDE project using the VisualGDB Embedded Project Wizard.
November 10, 2022 at 12:18 #33425Gast
ParticipantI do have a complete “STM32CubeMx project” containing all the source files and in addition an ioc file that was edited according to the target type, the ports, the clocks, etc.
When I try to import the project into Visualgdb, CubeMX is beeing opened requiring to produce a new ioc file which is very difficult to make it the same as the ioc file already existing, since one has to go through a lot of settings options..
Why is it not possible to use the fully prepared ioc file from the project folder to be imported?
You must be logged in to view attached files.November 10, 2022 at 12:21 #33427support
- Please make sure the steps do not involve any 3rd-party code as we will not be able to review it. If the problem only happens with a specific project, please make sure you can reproduce it on a clean project created from scratch. If the problem happens with a specific ioc file, please provide the steps (with full uncropped screenshots) how you create that file.
