How to use .so file?
Sysprogs forums › Forums › VisualGDB › How to use .so file?
  • #9080
    akhilavit
    I have built shared library using Linux configuration, say, akhil.so
    I have a Linux App Project MyApp and I want to so file. How to do this?
    I tried adding path and lib name in make file settings. When I try to apply it gives following error
    Tool arguments: -Wl,–start-group “/tmp/VisualGDB_ToolchainTestProgram.o” -o “/tmp/VisualGDB_ToolchainTestProgram” -Wl,-gc-sections -L/tmp/VisualGDB/c/projects/Test/LinuxProject3/LinuxProject3 -lRevLib.so -Wl,–end-group
    /usr/bin/ld: cannot find -lRevLib.so
    collect2: error: ld returned 1 exit status
    What is wrong and how to fix it?
    #9081
    akhilavit
    Kindly Tell me steps for this.
    And Where should I copy .so?
    Only .so is enough or should I have something else?
    #9086
    Normally all you need to do is add a reference to the .so project in the properties of your main project (right-click in Solution Explorer, Add Reference).
    #9104
    akhilavit
    The problem was with paths. It worked. Thanks
