How to make GDB ignore SIG34
Sysprogs forums Forums VisualGDB How to make GDB ignore SIG34
  • #35673
    Hans
    Hi there,
    I am using VisualGDB. The debugger stops when my timer times out. Attached is the screenshot when debugger stops.  Please let me know how I can configure the debugger not to stop on this event. Thanks and looking forward to hearing from you.
    #35675
    #35689
    Hans
    Hi the tech support period is still valid. The license is purchased under my boss’ name but I am using it.
    #35691
    Thanks, we have linked your key to your profile.
    You can configure the GDB signal handling behavior via the “signals” button in the GDB session window: https://visualgdb.com/documentation/gdbsession/#signals
