Sysprogs forums › Forums › VisualGDB › How to JTAG debugging multiple ESP32-WROVER Board.
- This topic has 1 reply, 2 voices, and was last updated 7 years, 8 months ago by
January 9, 2019 at 08:15 #23323
kevinn
I need to JTAG debugging two ESP32-WROVER board on the same computer.
But, it seems that VisualGDB OpenOCD always select the same board.
My question is how to configure VisualGDB to specify a speect ESP32-WROVER board to use?
Test Log below:
Open On-Chip Debugger 0.9.0 (2018-10-12)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 3000 kHz
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select <transport>’.
esp32 interrupt mask on
VisualGDB_OpenOCD_Ready
Info : clock speed 3000 kHz
Info : Target halted. PRO_CPU: PC=0x401354DE (active) APP_CPU: PC=0x401354DE
Info : Detected debug stubs @ 3ffb34e0 on core0 of target ‘esp32’
cpu0: Current bits set: BreakIn BreakOut RunStallIn
cpu1: Current bits set: BreakIn BreakOut RunStallIn
Info : accepting ‘gdb’ connection on tcp/2995
Info : Target halted. PRO_CPU: PC=0x4009170E (active) APP_CPU: PC=0x401354DE
Info : Flash mapping 0: 0x1 -> 0xfffffd01, 2097711 KB
Info : Flash mapping 1: 0x3ffc0610 -> 0x0, 0 KB
Info : Auto-detected flash size 4096 KB
Info : Using flash size 4096 KB
Info : Using flash size 0 KB
Info : dropped ‘gdb’ connection
Info : Restore debug stubs @ 3ffb34e0 on core0 of target ‘esp32’January 10, 2019 at 00:44 #23326support
Please try creating a temporary copy of the interface configuration file (e.g. esp32_devkitj_v1.cfg) and add the ftdi_serial command there (OpenOCD should show the serial numbers of connected devices if multiple matching adapters are found), then specify the copied script in the Debug Settings.
Normally VisualGDB should do this automatically, however we have not explicitly tested this with the ESP32 devices, so minor adjustments might be required. Feel free to let us know your observations and we should be able to update VisualGDB to do this automatically.
