Hi All,
Thanks @aronrubin for sharing your solution!
Editing CMakeLists.txt should indeed do the trick. If not, please check the generated .mak files for the compiler command lines (if -mfpu=neon-fp-armv8 does not appear there, the CMAKE_SYSTEM_PROCESSOR might not be matched properly).
If you would like to follow the tutorial linked above to the letter, you can use the VisualGDB Project Properties -> CMake Project Settings -> Extra CMake Configuration Variables setting to specify flags like ENABLE_NEON. E.g. simply “ENABLE_NEON=ON”.
