I’m targeting Raspberry pi, and set up the IP address for SSH connection. However I need to change the IP address. Tried changing the IP in the entry and it throws an error as it’s still trying to use the old IP. Does anyone know which config file I need to edit to fix this? There is no other place to change it in the UI.
