How to change source file locations?
Sysprogs forums Forums VisualGDB How to change source file locations?
  • This topic has 2 replies, 2 voices, and was last updated 6 years ago by sean.
  • #25405
    sean
    I have an mbed project and i want to share the version-controlled source code across the multiple tools. That-is, i want one location that holds my source-code, located in some place that is not within a VisualGDB mbed project. When i try this i get a message something like the following.
    The following files are outside the source directory for the xxxx.elf and will be ignored by mbed:
    Can this be fixed?
    #25413
    The easiest way to get this to would would be to manually add the source directory containing the files to VisualGDB project properties -> Extra Source Directories.
    We understand that it is an extra configuration step and will update VisualGDB to do it automatically in the next major release along with other mbed-related improvements.
    #25441
    sean
    This worked – thanks. I’ll look for the update.
