How do I add compile C++11 and add it to intelisense?
Sysprogs forums Forums VisualGDB How do I add compile C++11 and add it to intelisense?
  • This topic has 2 replies, 2 voices, and was last updated 12 years ago by ket.
  • #609
    theColonel26
    How do I compile for C++11 and which directories should add to the intellisense list?
    I’m using the cross-compiler for RPi BTW.
    #2540
    ket
    Even the newest gcc version has only experimental full c++11 support. Our Raspberry Pi cross-toolchain uses gcc version 4.6.3, as such it has only limited support for some c++0x features as listed at http://gcc.gnu.org/gcc-4.6/cxx0x_status.html .
    Add -std=c++0x to CFLAGS to enable support.
    #2539
    theColonel26
    that did it thanks.
