header files not being copied to linux side
Sysprogs forums › Forums › VisualGDB › header files not being copied to linux side
  • #6232
    rsc
    I was following the tutorial on how to adapt a windows QT project to run on Linux.
    When I try to build the code, I get the error: “EXEC : warning : Failure to find: CubicMVCs.h”. But that file is on my windows project, but I don’t know why it does not appear on my linux folder. It appears that the VisualGDB is not copying that header file (actually, when I compare the windows and linux folder, there are several files that are not being copied to the linux side).
    I already checked the VisualGDB configuration and set to transfer all files.
    Any idea why this is happening?
    #6233
    rsc
    My fault. I just notice that although the file appears listed on my solution, the file indeed does not exist on my windows folder. And the error message is actually an warning and not an error. So, that was not the cause of the code not being built.
