Hardware register file not-persisted
Sysprogs forums Forums VisualGDB Hardware register file not-persisted
  • #10746
    sidprice
    In my embedded project I keep having to select the SVD file for the hardware registers view, it doesn’t appear to be saved with the project.
    Is this a bug or a setting I have wrong?
    Sid
    #10753
    Normally the reference to the imported hardware register file should be saved to the <mcu>.xml file in your project directory (see the EmbeddedProfileFile element in the .vgdbsettings file).
    Please ensure that this file exists and is writable.
    #10788
    sidprice
    I re selected the SVD file in the hardware register window and a file named “STM32411xx.mcudef” is now in my project folder. That name also appears in “STM32.XML”. I am not sure what makes it “dissappear”, however in the past the hardware register window seems to “forget” this setting. I will try to monitor when it occurs.
    Sid.
