Sysprogs forums › Forums › VisualGDB › Hal Timer not accurate (off by 4 seconds) stm32 f10x
- This topic has 4 replies, 2 voices, and was last updated 9 years, 3 months ago by
January 7, 2017 at 17:13 #9961
Sir.Kovek
ParticipantI’m using the the stm32f103c8 (t6) and debugging using the St link v2.
Running on the standard nano-lib:
Led should blink on and off every 500ms, blinking roughly every 4.5 seconds
Open cd output:
Open On-Chip Debugger 0.9.0 (2016-10-14) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport “hla_swd”. To override use ‘transport s
elect <transport>’.
Info : The selected transport took over low-level target control. The results might differ comp
ared to plain JTAG/SWD
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : clock speed 950 kHz
Info : STLINK v2 JTAG v27 API v2 SWIM v6 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.246224
Info : stm32f1x.cpu: hardware has 6 breakpoints, 4 watchpoints
stm32f1x.cpu: target state: halted
xPSR: 0x01000000 pc: 0x0800038c msp: 0x20005000
VisualGDB_OpenOCD_Ready
Info : accepting ‘gdb’ connection on tcp/21776
Info : device id = 0x20036410
Info : flash size = 64kbytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x2000003a msp: 0x20005000
xPSR: 0x01000000 pc: 0x0800038c msp: 0x20005000I’m very new to the embedded world but have significant experience in C/C++ and other language such as C#(irrelevant). I got myself the board since i want to create my own quad copter controller as a challenge to myself, i also picked up a discovery book for the stm32 f10x which walks your through the standard lib and more (I’m hoping to be able to easily translate what he’s doing in to the HAL on VisualGDB). I’ve set the on board LED to blink every 500 ms but it isn’t, it way off blinking at 4.5 seconds(roughly).
Does anyone know what’s going on? The board is getting plenty of power, even plugged it into an external battery, so i can exclude that, plus it’s not resetting randomly. JTAG is blink away (red and green) when debugging if thats of any help.
January 7, 2017 at 19:20 #9963support
Most likely the HSE_VALUE macro defined in your project configuration does not match the speed of the clock oscillator on your board. Please double-check your project configuration and the board schematics.
January 7, 2017 at 22:47 #9972Sir.Kovek
ParticipantThe clock is the same as the external oscillator running at 8mhz, Even after re-creating the project i’m still getting the same result, Here an image of the settings
https://s29.postimg.org/aromgek6v/Screenshot_2017_01_07_21_41_34.png
January 7, 2017 at 23:07 #9973Sir.Kovek
ParticipantThe board runs at 70mhz with PLL
January 8, 2017 at 17:58 #9980support
Thanks for clarifying this. Looks like in the latest STM32 BSP there is a small bug that prevents the oscillator speed from the wizard from being set in the project configuration.
Please locate the stm32xxx_hal_conf.h file in your project and then double-check the HSE_VALUE defined there:
#if !defined (HSE_VALUE) #define HSE_VALUE ((uint32_t)25000000U) /*!< Value of the External oscillator in Hz */ #endif /* HSE_VALUE */
Also the default LEDBlink project does not automatically configure the PLL. To do that you can generate the configuration code using the STM32Cube software, or copy it from one of other examples for your board. The typical clock configuration function looks like this:
static void SystemClock_Config(void) { RCC_ClkInitTypeDef RCC_ClkInitStruct; RCC_OscInitTypeDef RCC_OscInitStruct; /* Enable HSE Oscillator and Activate PLL with HSE as source */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; RCC_OscInitStruct.HSEState = RCC_HSE_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1; RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6; if (HAL_RCC_OscConfig(&RCC_OscInitStruct)!= HAL_OK) { Error_Handler(); } /* Select PLL as system clock source and configure the HCLK, PCLK1 clocks dividers */ RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1); RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1)!= HAL_OK) { Error_Handler(); } } -
