Sysprogs forums › Forums › VisualGDB › Getting "Error:initmode failed (unable to connect to the target)
- This topic has 2 replies, 2 voices, and was last updated 4 years, 1 month ago by
GeneM.
February 21, 2022 at 08:20 #32279
GeneM
ParticipantEverything has been working fine for quite a while. I started learning how to use the LPTIMER on the STM32 Nucleo-H7A3ZI-q that I’ve been using for a long time. I got the STM example working and powered down. Now, when I try to run my example program, or any other program, I get a “init mode failed (unable to connect to the target)” error. When I click on “view gdb stub log” I get this:
VisualGDB: restarting tool…
Open On-Chip Debugger 0.11.0 (2021-06-25) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
Info : clock speed 1800 kHz
Info : STLINK V3J9M3 (API v3) VID:PID 0483:374E
Info : Target voltage: 3.293023
Error: init mode failed (unable to connect to the target)I get the same error for other programs I’ve written that have been working for a long time. The LPTIMER program I was working on periodically puts the MCU in a low power state and then wakes it up in case that is part of the problem.
I get the same error if I try to build a new project. While setting up the debugger for the new project I can hit the test open OCD button and get this similar error.
C:\Users\gene\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 52743” -c “telnet_port 52741” -f interface/stlink.cfg -f target/stm32h7x_dual_bank.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
Error: init mode failed (unable to connect to the target)Luckily I have another Nucleo-H7A3ZI-Q board and it does not exhibit this error.
Any suggestions will be greatly appreciated. Thanks
February 21, 2022 at 08:23 #32281support
KeymasterSorry, this looks like an issue with your board, and not something specific to VisualGDB.
February 21, 2022 at 08:44 #32283GeneM
ParticipantI was afraid of that too. But I had what turned out to be a good idea. I used STM32CubeIDE to run the same STM LPTIMER example on the “failed” Nucelo board and it worked. I tried my original LPTIMER example using VisualGDB and it works too. So does the main project I’ve been working on. It may be related to me powering down the Nucleo board while the program was in the low power state and VGDB not being able to wake it up but that is way beyond my skill set. Thanks for the quick response.
