Get CPU device from code (build defines)
Sysprogs forums Forums VisualGDB Get CPU device from code (build defines)
  • #26717
    MrZANE
    Hi
    I have a device connecting to a cloud server and would like to report the CPU device type (Fex. STM32L431CC) selected in the Project->VisualGDB Project Properties->Embedded Project to the cloud (As we might change the CPU at a later time).
    Is there a way to get the selected CPU device in code (Preferably as a string)?
    I tried to enable the verbos build output (tools->Options->VisualGDB->General->Output->Enabled verbose = true) to see what kind buildtime defines there were but I couldn’t get it to output any more info than the filenames as they compiled.
    Is that the right way to enable complete build commands?
    Kind regards
    Jimmy
    #26718
    If you are using MSBuild, the output verbosity is controlled by Visual Studio itself and can be configured via Tools->Options->Projects and Solutions->Build and Run.
    You can also find the preprocessor macros in the .rsp files inside your build directory (search for -D<macro> strings).
    Normally, something like this would work:
    #ifdef STM32L431CC
    Report.DeviceType = MyIDForSTM32L431CC;
    #elif defined (...)
    Report.DeviceType = MyIDForSomethingElse;
    #else
    #error Unknown device. Add a check for it above.
    #endif
    #26762
    MrZANE
    That works just fine.
    Thanks for your help.
    Kind regards
    Jimmy
