Sysprogs forums › Forums › VisualGDB › Geehy APM32 MCU support
- This topic has 4 replies, 2 voices, and was last updated 2 years ago by
matstumpf.
December 22, 2023 at 08:29 #35174
matstumpf
ParticipantHi!
I normally use ST STM32 devices without any issue, but on the last batch of PCBs we received, the supplier changed to Geehy APM32.
Well, I use ST-Link V2, and I could program without issues and also debug for some seconds.
Also, the DFU bootloader wont work and eighter the Board Config that I store on Flash, and as i cannot debug for more than 10 seconds, I cannot see what is going wrong.
This is the VisualGDB output:
Hi!
C:\Users\i9-matsRD\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 58217” -c “telnet_port 58215” -f interface/stlink-v2.cfg -c “transport select hla_swd” -f target/stm32f4x.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.12.0 (2023-10-02) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
For bug reports, read
WARNING: interface/stlink-v2.cfg is deprecated, please switch to interface/stlink.cfg
hla_swd
Info : clock speed 2000 kHz
Info : STLINK V2J39S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.254076
Info : [stm32f4x.cpu] Cortex-M4 r0p1 processor detected
Info : [stm32f4x.cpu] target has 6 breakpoints, 4 watchpoints
Info : starting gdb server for stm32f4x.cpu on 58217
Info : Listening on port 58217 for gdb connections
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
[stm32f4x.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08007aac msp: 0x20020000
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
Info : Listening on port 58215 for telnet connections
Info : accepting ‘gdb’ connection on tcp/58217
Info : device id = 0x0015a433
Info : flash size = 512 KiB
Info : flash size = 512 bytes
Warn : Prefer GDB command “target extended-remote :58217” instead of “target remote :58217”
Info : Erasing FLASH: 0x08000000-0x0800c000…
Info : Programming FLASH (2 sections, 36200 bytes)…
Info : Programming FLASH section 1/2 (408 bytes) at 0x08000000…
Info : Padding image section 0 at 0x08000198 with 8 bytes
Info : flash_write_start:0x8000000|0x8008d70|stm32f4x.flash
Info : flash_write_done:stm32f4x.flash
Info : halted: PC: 0x08000e58
Info : halted: PC: 0x08000670
Info : halted: PC: 0x08000672
Info : halted: PC: 0x080044e6
Info : halted: PC: 0x08000678
Info : halted: PC: 0x0800067a
Info : halted: PC: 0x0800067e
Info : halted: PC: 0x08000680
Info : halted: PC: 0x08000682
Info : halted: PC: 0x08000684
Info : halted: PC: 0x08000686
Info : halted: PC: 0x08000688
Info : halted: PC: 0x0800068a
Info : halted: PC: 0x0800068c
Info : halted: PC: 0x0800068e
Info : halted: PC: 0x08000690
Info : halted: PC: 0x08000692
Info : halted: PC: 0x08000694
Info : halted: PC: 0x08000696
Info : halted: PC: 0x08000698
Info : halted: PC: 0x0800069a
Info : halted: PC: 0x0800069c
Info : halted: PC: 0x0800069e
Info : halted: PC: 0x080006a0
Info : halted: PC: 0x080006a2
Info : halted: PC: 0x080006a4
Info : halted: PC: 0x080006a6
Info : halted: PC: 0x080006a8
Info : halted: PC: 0x080006aa
Info : halted: PC: 0x080006ac
Info : halted: PC: 0x080006ae
Error: jtag status contains invalid mode value – communication failure
Polling target stm32f4x.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Info : Previous state query failed, trying to reconnect
Examination failed, GDB will be halted. Polling again in 300ms
Polling target stm32f4x.cpu failed, trying to reexamineThere are some thing that I can do to make it work? Anyone tried?
Thanks!
Thanks!
December 22, 2023 at 08:33 #35177support
The ST-Link devices are specifically designed to work with ST microcontrollers only, so it makes sense that they wouldn’t work with APM32. You can try contacting the device vendor- maybe they supply their own version of ST-Link or OpenOCD.
December 22, 2023 at 08:56 #35181matstumpf
ParticipantYes they have their own programmer (Geehy-Link), but as others Chinese stm32 copy MCUs that works only changing the id with the ST-Link, this should work too, as it programs successful (I can test my PCB and it works) but the debug connection drop suddenly.
How can i check why it’s dropping?
December 22, 2023 at 09:24 #35182support
KeymasterYou can try contacting the device vendor, or your supplier. Maybe, they could have some suggestions.
As far as VisualGDB is concerned, it runs OpenOCD in order to handle the low-level debug functionality. The STM32 support in OpenOCD is developed by ST and generally works very well with genuine ST devices. If it’s not working with a particular device, the issue is somewhere between OpenOCD and that specific device. If you can get OpenOCD working via command line, we can help you configure VisualGDB to use that command line when you start a debug session. If not, it won’t work with VisualGDB either.
March 8, 2024 at 04:21 #35412matstumpf
ParticipantHi!
I ended up buying a Segger J-Link programmer and could make it work without any issues.
Strangely the default ST-Link programmer do program fine, but only debug for few seconds.
