Sysprogs forums › Forums › VisualGDB › GDB server terminated unexpectedly
- This topic has 3 replies, 3 voices, and was last updated 14 years ago by
derodo.
August 26, 2012 at 06:42 #565
Parminder
ParticipantHi Everyone,
I am trying the VisualGDB version for debugging the Android-NDK code for OpenGLES. I setup the instruction carefully and went through the OpenGlES tutorial properly.
When I tried to Debug the application using VisualGDB it launches the application properly on my HTC SYNC device but unable to debug and gives an error. Can you please help me to resolve this problem, this tool seems very promising to us for making the developement easy.ERROR >> GDBSERVER terminated unexpectedly
Following are the GDB debugging log messages-
1) GDB Log:-
^done
-gdb-set solib-search-path C:/Users/Parminder/AppData/Local/VisualGDB/AndroidBinaryCache/SH1BGV807888;E:/eDriveOrg/Study/OpenGL/OpenGl/3DS/swampBoat/Gl2Wrapper/Gl2Wrapper/obj/local/armeabi
^done
-target-select remote :5039
^error,msg=”putpkt: write failed: No error.”========================================================
2) Gdbserver log:-
run-as: Package ‘com.android.gl2jni’ is unknown
3) ADB Log:-
C:androidandroid-sdkplatform-toolsadb.exe devices
List of devices attached
SH1BGV807888 device
Command exited with code 0
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 shell ps
USER PID PPID VSIZE RSS WCHAN PC NAME
root 1 0 428 288 ffffffff 00000000 S /init
root 2 0 0 0 ffffffff 00000000 S kthreadd
root 3 2 0 0 ffffffff 00000000 S ksoftirqd/0
root 4 2 0 0 ffffffff 00000000 S migration/0
root 7 2 0 0 ffffffff 00000000 R events/0
root 9 2 0 0 ffffffff 00000000 S khelper
root 10 2 0 0 ffffffff 00000000 S async/mgr
root 11 2 0 0 ffffffff 00000000 S pm
root 12 2 0 0 ffffffff 00000000 S suspend
root 13 2 0 0 ffffffff 00000000 S irq/344-pm8058-
root 14 2 0 0 ffffffff 00000000 S irq/347-pm8901-
root 15 2 0 0 ffffffff 00000000 S sync_supers
root 16 2 0 0 ffffffff 00000000 S bdi-default
root 17 2 0 0 ffffffff 00000000 S kblockd/0
root 19 2 0 0 ffffffff 00000000 S khubd
root 20 2 0 0 ffffffff 00000000 S kmmcd
root 21 2 0 0 ffffffff 00000000 S tty_smd0/0
root 23 2 0 0 ffffffff 00000000 S tps65200
root 24 2 0 0 ffffffff 00000000 S msm_adc
root 25 2 0 0 ffffffff 00000000 S kondemand/0
root 27 2 0 0 ffffffff 00000000 S modem_notifier
root 28 2 0 0 ffffffff 00000000 S smd_channel_clo
root 29 2 0 0 ffffffff 00000000 S charger_ctrl_ti
root 30 2 0 0 ffffffff 00000000 S batt_timer
root 31 2 0 0 ffffffff 00000000 S detect/0
root 33 2 0 0 ffffffff 00000000 S button/0
root 35 2 0 0 ffffffff 00000000 S HS_PMIC_DETECT/
root 37 2 0 0 ffffffff 00000000 S HS_PMIC_BUTTON/
root 39 2 0 0 ffffffff 00000000 S HS_8X60_BUTTON/
root 41 2 0 0 ffffffff 00000000 S HS_GPIO_DETECT/
root 43 2 0 0 ffffffff 00000000 S HS_GPIO_BUTTON/
root 45 2 0 0 ffffffff 00000000 S kswapd0
root 46 2 0 0 ffffffff 00000000 S aio/0
root 48 2 0 0 ffffffff 00000000 S ecryptfs-kthrea
root 49 2 0 0 ffffffff 00000000 S crypto/0
root 61 2 0 0 ffffffff 00000000 S mdp_dma_wq
root 62 2 0 0 ffffffff 00000000 S mdp_vsync_wq
root 63 2 0 0 ffffffff 00000000 S mdp_pipe_ctrl_w
root 64 2 0 0 ffffffff 00000000 S mdp_cursor_ctrl
root 65 2 0 0 ffffffff 00000000 S hdmi_hdcp/0
root 67 2 0 0 ffffffff 00000000 S irq/111-hdmi_ms
root 68 2 0 0 ffffffff 00000000 S vidc_worker_que
root 69 2 0 0 ffffffff 00000000 S vidc_timer_wq
root 70 2 0 0 ffffffff 00000000 S mhl_sii9234_wq/
root 72 2 0 0 ffffffff 00000000 S diag_wq
root 73 2 0 0 ffffffff 00000000 S msm_serial_hs
root 74 2 0 0 ffffffff 00000000 S msm_hs_ti_d_wq
root 75 2 0 0 ffffffff 00000000 S msm_serial_hs
root 76 2 0 0 ffffffff 00000000 S msm_hs_brcm_wq
root 77 2 0 0 ffffffff 00000000 S pmic8058_vib_wq
root 78 2 0 0 ffffffff 00000000 S cable_detect
root 79 2 0 0 ffffffff 00000000 S spi_qsd.0
root 86 2 0 0 ffffffff 00000000 S k_otg
root 87 2 0 0 ffffffff 00000000 S msm_hsusb
root 88 2 0 0 ffffffff 00000000 S file-storage
root 89 2 0 0 ffffffff 00000000 S gs_tty
root 90 2 0 0 ffffffff 00000000 S cypress_touch
root 91 2 0 0 ffffffff 00000000 S isl29029_wq
root 92 2 0 0 ffffffff 00000000 S irq/210-tsens
root 93 2 0 0 ffffffff 00000000 S kstriped
root 94 2 0 0 ffffffff 00000000 S kconservative/0
root 96 2 0 0 ffffffff 00000000 D kinteractiveup
root 97 2 0 0 ffffffff 00000000 S kinteractive_do
root 99 2 0 0 ffffffff 00000000 S emmc-qd
root 100 2 0 0 ffffffff 00000000 S led/0
root 102 2 0 0 ffffffff 00000000 S binder
root 103 2 0 0 ffffffff 00000000 S l2cap
root 104 2 0 0 ffffffff 00000000 S msm_watchdog_wq
root 105 2 0 0 ffffffff 00000000 S kgsl-3d0/0
root 107 2 0 0 ffffffff 00000000 S kgsl-2d0/0
root 109 2 0 0 ffffffff 00000000 S kgsl-2d1/0
root 111 1 316 168 ffffffff 00000000 S /sbin/ueventd
root 112 2 0 0 ffffffff 00000000 S jbd2/mmcblk0p22
root 113 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
root 115 2 0 0 ffffffff 00000000 S sd-qd
root 116 2 0 0 ffffffff 00000000 S jbd2/mmcblk0p23
root 117 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
root 119 2 0 0 ffffffff 00000000 S jbd2/mmcblk0p24
root 120 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
root 122 2 0 0 ffffffff 00000000 S jbd2/mmcblk0p27
root 123 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
system 125 1 860 136 ffffffff 00000000 S /system/bin/servicemanager
root 126 1 3944 340 ffffffff 00000000 S /system/bin/vold
root 127 1 3952 280 ffffffff 00000000 S /system/bin/netd
root 128 1 3236 256 ffffffff 00000000 S /system/bin/debuggerd
radio 129 1 16892 564 ffffffff 00000000 S /system/bin/rild
root 130 1 101076 24004 ffffffff 00000000 S zygote
media 131 1 44108 3452 ffffffff 00000000 S /system/bin/mediaserver
root 132 1 12324 660 ffffffff 00000000 S /system/bin/htcfs
bluetooth 133 1 1312 120 ffffffff 00000000 S /system/bin/dbus-daemon
root 134 1 868 232 ffffffff 00000000 S /system/bin/installd
keystore 135 1 1820 172 ffffffff 00000000 S /system/bin/keystore
root 136 1 844 160 ffffffff 00000000 S /system/bin/ipd
root 139 1 9116 208 ffffffff 00000000 S /system/bin/qmuxd
radio 140 1 4360 328 ffffffff 00000000 S /system/bin/netmgrd
root 141 1 6048 276 ffffffff 00000000 S /system/bin/hdmid
root 142 1 320 136 ffffffff 00000000 S /system/bin/htcbatt
root 147 1 9492 76 ffffffff 00000000 S /system/bin/rmt_storage
root 148 1 1112 248 ffffffff 00000000 S /system/bin/htc_ebdlogd
root 208 148 1856 1360 ffffffff 00000000 S /system/bin/logcat2
root 232 2 0 0 ffffffff 00000000 S flush-179:0
root 240 2 0 0 ffffffff 00000000 S rpcrouter
root 241 2 0 0 ffffffff 00000000 D rpcrotuer_smd_x
root 242 2 0 0 ffffffff 00000000 S krpcserversd
root 243 2 0 0 ffffffff 00000000 D krmt_storagecln
root 244 2 0 0 ffffffff 00000000 D krmt_storagecln
system 253 130 313640 46532 ffffffff 00000000 S system_server
root 463 2 0 0 ffffffff 00000000 S iscan_sysioc
root 464 2 0 0 ffffffff 00000000 S dhcp_sysioc
root 465 2 0 0 ffffffff 00000000 S wlp_sysioc
root 466 2 0 0 ffffffff 00000000 S dhd_watchdog
root 467 2 0 0 ffffffff 00000000 S dhd_dpc
root 468 2 0 0 ffffffff 00000000 S dhd_sysioc
system 493 130 157524 30096 ffffffff 00000000 S com.android.systemui
radio 529 130 152672 34880 ffffffff 00000000 S com.android.phone
app_19 534 130 188956 26372 ffffffff 00000000 S android.process.acore
log 579 1 712 88 ffffffff 00000000 S /system/bin/logwrapper
wifi 582 579 2264 528 ffffffff 00000000 S /system/bin/wpa_supplicant
root 705 1 3936 204 ffffffff 00000000 S /system/bin/thermald
root 706 1 4172 196 ffffffff 00000000 S /system/bin/mpdecision
root 800 1 14588 720 ffffffff 00000000 S /system/bin/DxDrmServerIpc
app_4 4985 130 174808 35976 ffffffff 00000000 S com.htc.idlescreen.shortcut
system 5019 253 0 0 ffffffff 00000000 Z Error dump: HTC
app_98 5031 130 139300 24000 ffffffff 00000000 S com.htc.android.htcime
app_11 5040 130 128856 30596 ffffffff 00000000 S com.htc.bgp
app_127 5106 130 128068 18172 ffffffff 00000000 S com.qi.appiq
nobody 5351 130 369160 104828 ffffffff 00000000 S com.htc.launcher
app_96 5368 130 114432 17080 ffffffff 00000000 S com.htc.RosieUtility
app_50 5382 130 123104 20644 ffffffff 00000000 S com.android.mms
app_44 5431 130 150960 23772 ffffffff 00000000 S com.google.process.gapps
app_109 5525 130 119808 25248 ffffffff 00000000 S com.facebook.katana
app_161 5543 130 149272 23244 ffffffff 00000000 S com.whatsapp
app_111 5711 130 111724 15712 ffffffff 00000000 S com.android.defcontainer
app_11 5722 130 111756 15844 ffffffff 00000000 S com.htc.opensense
app_11 5729 130 112148 15948 ffffffff 00000000 S com.htc.cs
app_73 5764 130 111836 16384 ffffffff 00000000 S com.htc.recommend
app_18 5794 130 133452 19256 ffffffff 00000000 S com.android.vending
app_142 5819 130 111940 15896 ffffffff 00000000 S com.keypoint.demoapp
app_40 5828 130 110648 15408 ffffffff 00000000 S com.svox.pico
app_102 5837 130 110844 15624 ffffffff 00000000 S com.google.android.partnersetup
app_54 5845 130 118132 17616 ffffffff 00000000 S com.google.android.apps.maps:FriendService
app_54 5853 130 137072 20780 ffffffff 00000000 S com.google.android.apps.maps:NetworkLocationService
app_101 5860 130 114772 16916 ffffffff 00000000 S com.google.android.googlequicksearchbox
app_19 5928 130 195236 25028 ffffffff 00000000 S com.android.htccontacts
app_11 6708 130 122632 22772 ffffffff 00000000 S com.htc.bg
app_42 7133 130 111724 17108 ffffffff 00000000 S com.pv.wmdrmservice
app_47 7141 130 112136 16716 ffffffff 00000000 S com.htc.reportagent
app_51 7151 130 113064 15876 ffffffff 00000000 S com.google.android.apps.uploader
app_77 7160 130 110680 15660 ffffffff 00000000 S com.htc.htcMessageUploader
app_104 7170 130 114368 17228 ffffffff 00000000 S com.google.android.gm
app_157 7178 130 117504 18132 ffffffff 00000000 S com.joelapenna.foursquared
app_129 7653 130 116064 20352 ffffffff 00000000 S com.fd.httpd
system 7690 130 110632 15952 ffffffff 00000000 S com.pv.wmdrmproxy
system 8413 130 128220 28780 ffffffff 00000000 S com.android.settings
9997 9116 130 127844 26580 ffffffff 00000000 S com.htc.android.mail
system 10675 130 120220 26984 ffffffff 00000000 S com.htc.android.worldclock
app_23 10689 130 110836 17144 ffffffff 00000000 S com.muvee.video.trimer
app_32 10708 130 111320 17640 ffffffff 00000000 S com.htc.skinpicker
app_83 10848 130 111904 17852 ffffffff 00000000 S com.htc.laputa.HtcLaputaInstaller
shell 11117 1 3456 200 ffffffff 00000000 S /sbin/adbd
9994 11741 130 114708 18736 ffffffff 00000000 S com.htc.googlereader
app_14 12159 130 136408 20200 ffffffff 00000000 S com.sdgtl.watch
app_112 12594 130 110684 16832 ffffffff 00000000 S com.htc.demoflopackageinstaller
app_54 12607 130 127600 24020 ffffffff 00000000 S com.google.android.apps.maps
app_130 12947 130 114508 22632 ffffffff 00000000 S com.android.gl2jni
app_52 13023 130 114884 23544 ffffffff 00000000 S android.process.media
dhcp 13163 1 904 408 ffffffff 00000000 S /system/bin/dhcpcd
shell 13259 11117 788 336 c00b4b08 afd0c4bc S /system/bin/sh
shell 13260 13259 944 332 00000000 afd0b56c R ps
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 shell id
uid=2000(shell) gid=2000(shell) groups=1003(graphics),1004(input),1007(log),1009(mount),1011(adb),1015(sdcard_rw),3001(net_bt_admin),3002(net_bt),3003(inet)
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 shell run-as com.android.gl2jni kill -9 12947
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 install -r “E:eDriveOrgStudyOpenGLOpenGl3DSswampBoatGl2WrapperGl2WrapperbinGL2JNIActivity-debug.apk”
pkg: /data/local/tmp/GL2JNIActivity-debug.apk
Success
2307 KB/s (167792 bytes in 0.071s)
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 shell run-as com.android.gl2jni /system/bin/sh -c pwd
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 shell getprop ro.product.cpu.abi
armeabi-v7a
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 shell am start -n com.android.gl2jni/.GL2JNIActivity
Starting: Intent { cmp=com.android.gl2jni/.GL2JNIActivity }
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 shell ls /data/data/com.android.gl2jni/lib/gdbserver
root 7 2 0 0 ffffffff 00000000 S events/0
system 253 130 366220 99540 ffffffff 00000000 S system_server
app_19 534 130 184860 26332 ffffffff 00000000 S android.process.acore
nobody 5351 130 370572 124484 ffffffff 00000000 R com.htc.launcher
app_96 5368 130 122628 17092 ffffffff 00000000 S com.htc.RosieUtility
app_161 5543 130 141080 23236 ffffffff 00000000 S com.whatsapp
app_111 5711 130 111736 15728 ffffffff 00000000 S com.android.defcontainer
app_11 5722 130 115852 15856 ffffffff 00000000 S com.htc.opensense
app_11 5729 130 112148 15956 ffffffff 00000000 S com.htc.cs
app_73 5764 130 111836 16400 ffffffff 00000000 S com.htc.recommend
app_142 5819 130 111940 15900 ffffffff 00000000 S com.keypoint.demoapp
app_40 5828 130 110648 15412 ffffffff 00000000 S com.svox.pico
app_102 5837 130 110844 15628 ffffffff 00000000 S com.google.android.partnersetup
app_54 5845 130 122228 17620 ffffffff 00000000 S com.google.android.apps.maps:FriendService
app_19 5928 130 142276 25568 ffffffff 00000000 R com.android.htccontacts
system 10675 130 120220 26988 ffffffff 00000000 S com.htc.android.worldclock
root 13288 2 0 0 ffffffff 00000000 S migration/1
root 13291 2 0 0 ffffffff 00000000 S ksoftirqd/1
root 13292 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
root 13293 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
root 13294 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
root 13295 2 0 0 ffffffff 00000000 S ext4-dio-unwrit
root 13296 2 0 0 ffffffff 00000000 S kgsl-2d1/1
root 13298 2 0 0 ffffffff 00000000 S kgsl-2d0/1
root 13299 2 0 0 ffffffff 00000000 S kgsl-3d0/1
root 13300 2 0 0 ffffffff 00000000 S led/1
root 13301 2 0 0 ffffffff 00000000 S kinteractive_do
root 13302 2 0 0 ffffffff 00000000 S kconservative/1
root 13303 2 0 0 ffffffff 00000000 S mhl_sii9234_wq/
root 13304 2 0 0 ffffffff 00000000 S hdmi_hdcp/1
root 13305 2 0 0 ffffffff 00000000 S crypto/1
root 13306 2 0 0 ffffffff 00000000 S aio/1
root 13307 2 0 0 ffffffff 00000000 S HS_GPIO_BUTTON/
root 13308 2 0 0 ffffffff 00000000 S HS_GPIO_DETECT/
root 13309 2 0 0 ffffffff 00000000 S HS_8X60_BUTTON/
root 13310 2 0 0 ffffffff 00000000 S HS_PMIC_BUTTON/
root 13311 2 0 0 ffffffff 00000000 S HS_PMIC_DETECT/
root 13312 2 0 0 ffffffff 00000000 S button/1
root 13313 2 0 0 ffffffff 00000000 S detect/1
root 13314 2 0 0 ffffffff 00000000 S kondemand/1
root 13315 2 0 0 ffffffff 00000000 S tty_smd0/1
root 13316 2 0 0 ffffffff 00000000 S kblockd/1
root 13317 2 0 0 ffffffff 00000000 S events/1
app_130 13329 130 123816 19944 ffffffff 00000000 R com.android.gl2jni
shell 13340 11117 788 336 c00b4b08 afd0c4bc S /system/bin/sh
shell 13341 13340 944 332 00000000 afd0b56c R ps
C:androidandroid-sdkplatform-toolsadb.exe -s SH1BGV807888 forward tcp:5039 tcp:5039
Command exited with code 0August 30, 2012 at 19:19 #2410support
Could you please post your AndroidManifest.xml file here?
September 7, 2012 at 16:26 #2412derodo
ParticipantHi. I’ve just downloaded and installed the evaluation version, and I’m having exactly the same issue.
I was able to debug on a Galaxy S2, but I’m still getting this error message when trying to debug on an HTC Desire.I’m attaching the manifest file just in case.
We here at virtway (http://www.virtway.com) are trying to find some nice alternatives to debug android native code than just plain gdb; and this really looks VERY promising.
Is there any hint we can use to try making it work on this specific device? (HTC Desire)September 8, 2012 at 13:03 #2411 -
