GDB breakpoint not getting hit
Sysprogs forums Forums VisualGDB GDB breakpoint not getting hit
  • #399
    Hi, my breakpoints aren’t getting hit. I’m running from inside vmplayer connecting to a host linux computer. Debugging works on the host in qtcreator, so it should work with VisualGDB too right? It executes fine, but no debugging. I set it up to use the vmplayer shared folder, (the “manual mapping” option). but this shouldn’t be a problem, the sources are now the same on both computers.
    Your VisualGDB trial expires in 30 days!
    gdb --interpreter mi --args "/home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo"
    =thread-group-added,id="i1"
    GNU gdb (GDB) SUSE (7.5.1-2.1.1)
    Copyright (C) 2012 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later
    There is NO WARRANTY, to the extent permitted by law. Type "show copying"
    and "show warranty" for details.
    This GDB was configured as "x86_64-suse-linux".
    Reading symbols from /home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo...
    done.
    -list-features
    ^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info","python"]
    OK
    -inferior-tty-set /dev/pts/4
    OK
    -data-list-register-names
    ^done,register-names=["rax","rbx","rcx","rdx","rsi","rdi","rbp","rsp","r8","r9","r10","r11","r12","r13","r14","r15","rip","eflags","cs","ss","ds","es","fs","gs","st0","st1","st2","st3","st4","st5","st6","st7","fctrl","fstat","ftag","fiseg","fioff","foseg","fooff","fop","xmm0","xmm1","xmm2","xmm3","xmm4","xmm5","xmm6","xmm7","xmm8","xmm9","xmm10","xmm11","xmm12","xmm13","xmm14","xmm15","mxcsr","","","","","","","","","","","","","","","","","orig_rax","al","bl","cl","dl","sil","dil","bpl","spl","r8l","r9l","r10l","r11l","r12l","r13l","r14l","r15l","ah","bh","ch","dh","ax","bx","cx","dx","si","di","bp","","r8w","r9w","r10w","r11w","r12w","r13w","r14w","r15w","eax","ebx","ecx","edx","esi","edi","ebp","esp","r8d","r9d","r10d","r11d","r12d","r13d","r14d","r15d"]
    OK
    -gdb-set print demangle off
    OK
    -gdb-version
    OK
    -break-insert -f main
    ^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00000000004015e7",func="main",file="simple_demo.c",fullname="/home/pc/Programming/libcrm114-20100726/simple_demo.c",line="131",times="0",original-location="main"}
    info target
    &"info targetn"
    Symbols from "/home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo".
    Local exec file:
    `/home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo', file type elf64-x86-64.
    Entry point: 0x4014f0
    0x0000000000400238 - 0x0000000000400254 is .interp
    0x0000000000400254 - 0x0000000000400274 is .note.ABI-tag
    0x0000000000400274 - 0x0000000000400298 is .note.gnu.build-id
    0x0000000000400298 - 0x000000000040041c is .hash
    0x0000000000400420 - 0x000000000040045c is .gnu.hash
    0x0000000000400460 - 0x00000000004009d0 is .dynsym
    0x00000000004009d0 - 0x0000000000400c24 is .dynstr
    0x0000000000400c24 - 0x0000000000400c98 is .gnu.version
    0x0000000000400c98 - 0x0000000000400d08 is .gnu.version_r
    0x0000000000400d08 - 0x0000000000400d38 is .rela.dyn
    0x0000000000400d38 - 0x00000000004011b8 is .rela.plt
    0x00000000004011b8 - 0x00000000004011d2 is .init
    0x00000000004011e0 - 0x00000000004014f0 is .plt
    0x00000000004014f0 - 0x000000000042dcf4 is .text
    0x000000000042dcf4 - 0x000000000042dcfd is .fini
    0x000000000042dd00 - 0x0000000000454cc0 is .rodata
    0x0000000000454cc0 - 0x00000000004558d4 is .eh_frame_hdr
    0x00000000004558d8 - 0x0000000000458a84 is .eh_frame
    0x0000000000658dc0 - 0x0000000000658dc8 is .init_array
    0x0000000000658dc8 - 0x0000000000658dd0 is .fini_array
    0x0000000000658dd0 - 0x0000000000658dd8 is .jcr
    0x0000000000658dd8 - 0x0000000000658ff8 is .dynamic
    0x0000000000658ff8 - 0x0000000000659000 is .got
    0x0000000000659000 - 0x0000000000659198 is .got.plt
    0x00000000006591a0 - 0x00000000006591ec is .data
    0x0000000000659200 - 0x00000000006d9278 is .bss
    OK
    -break-insert -f /home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo.c:129
    &"No source file named /home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo.c.n"
    ^done,bkpt={number="2",type="breakpoint",disp="keep",enabled="y",addr="",pending="/home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo.c:129",times="0",original-location="/home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo.c:129"}
    -file-list-exec-source-files
    ^done,files=[{file="simple_demo.c",fullname="/home/pc/Programming/libcrm114-20100726/simple_demo.c"},{file="texts.h",fullname="/home/pc/Programming/libcrm114-20100726/texts.h"},{file="/usr/include/bits/time.h",fullname="/usr/include/bits/time.h"},{file="/usr/include/sys/times.h",fullname="/usr/include/sys/times.h"},{file="/usr/include/time.h",fullname="/usr/include/time.h"},{file="/usr/include/bits/confname.h",fullname="/usr/include/bits/confname.h"},{file="crm114_lib.h",fullname="/home/pc/Programming/libcrm114-20100726/crm114_lib.h"},{file="/usr/lib64/gcc/x86_64-suse-linux/4.7/include/stddef.h",fullname="/usr/lib64/gcc/x86_64-suse-linux/4.7/include/stddef.h"},{file="/usr/include/bits/types.h",fullname="/usr/include/bits/types.h"},{file="../sysdeps/x86_64/crtn.S"},{file="elf-init.c"},{file="crm114_regex_tre.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_regex_tre.c"},{file="crm114_util.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_util.c"},{file="crm114_strnhash.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_strnhash.c"},{file="crm114_vector_tokenize.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_vector_tokenize.c"},{file="crm114_matrix_util.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix_util.h"},{file="crm114_datalib.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_datalib.c"},{file="crm114_matrix_util.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix_util.h"},{file="crm114_matrix_util.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_matrix_util.c"},{file="crm114_matrix.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix.h"},{file="crm114_matrix_util.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix_util.h"},{file="crm114_matrix.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_matrix.c"},{file="crm114_matrix.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix.h"},{file="crm114_pca_lib_fncts.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_pca_lib_fncts.c"},{file="crm114_matrix.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix.h"},{file="crm114_pca.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_pca.c"},{file="crm114_fast_substring_compression.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_fast_substring_compression.c"},{file="crm114_matrix.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix.h"},{file="crm114_svm_quad_prog.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_svm_quad_prog.c"},{file="crm114_matrix.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix.h"},{file="crm114_svm_lib_fncts.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_svm_lib_fncts.c"},{file="crm114_matrix.h",fullname="/home/pc/Programming/programming_shared/libcrm114-20100726/crm114_matrix.h"},{file="crm114_svm.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_svm.c"},{file="crm114_hyperspace.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_hyperspace.c"},{file="crm114_bit_entropy.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_bit_entropy.c"},{file="crm114_markov_microgroom.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_markov_microgroom.c"},{file="crm114_markov.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_markov.c"},{file="crm114_base.c",fullname="/home/pc/Programming/libcrm114-20100726/crm114_base.c"},{file="../sysdeps/x86_64/crti.S"},{file="init.c"},{file="../sysdeps/x86_64/start.S"}]
    -exec-run
    =thread-group-started,id="i1",pid="11151"
    =thread-created,id="1",group-id="i1"
    ^running
    *running,thread-id="all"
    =library-loaded,id="/lib64/ld-linux-x86-64.so.2",target-name="/lib64/ld-linux-x86-64.so.2",host-name="/lib64/ld-linux-x86-64.so.2",symbols-loaded="0",thread-group="i1"
    &"Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2n"
    &"Try: zypper install -C "debuginfo(build-id)=ecb8ef1a6904a2a3ec60a527f415f520c8636158"n"
    =library-loaded,id="linux-vdso.so.1",target-name="linux-vdso.so.1",host-name="linux-vdso.so.1",symbols-loaded="0",thread-group="i1"
    *stopped,reason="solib-event",added=[library="linux-vdso.so.1"],thread-id="1",stopped-threads="all",core="0"
    -break-list
    ^done,BreakpointTable={nr_rows="2",nr_cols="6",hdr=[{width="7",alignment="-1",col_name="number",colhdr="Num"},{width="14",alignment="-1",col_name="type",colhdr="Type"},{width="4",alignment="-1",col_name="disp",colhdr="Disp"},{width="3",alignment="-1",col_name="enabled",colhdr="Enb"},{width="18",alignment="-1",col_name="addr",colhdr="Address"},{width="40",alignment="2",col_name="what",colhdr="What"}],body=[bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00000000004015e7",func="main",file="simple_demo.c",fullname="/home/pc/Programming/libcrm114-20100726/simple_demo.c",line="131",times="0",original-location="main"},bkpt={number="2",type="breakpoint",disp="keep",enabled="y",addr="
    ",pending="/home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo.c:129",times="0",original-location="/home/pc/Programming/programming_shared/libcrm114-20100726/simple_demo.c:129"}]}
    info shared
    &"info sharedn"
    From To Syms Read Shared Object Library
    0x00007ffff7ddbac0 0x00007ffff7df4be9 Yes /lib64/ld-linux-x86-64.so.2
    No linux-vdso.so.1
    OK
    -exec-continue
    ^running
    *running,thread-id="1"
    =library-loaded,id="/usr/local/lib64/libtre.so.5",target-name="/usr/local/lib64/libtre.so.5",host-name="/usr/local/lib64/libtre.so.5",symbols-loaded="0",thread-group="i1"
    =library-loaded,id="/lib64/libm.so.6",target-name="/lib64/libm.so.6",host-name="/lib64/libm.so.6",symbols-loaded="0",thread-group="i1"
    =library-loaded,id="/lib64/libc.so.6",target-name="/lib64/libc.so.6",host-name="/lib64/libc.so.6",symbols-loaded="0",thread-group="i1"
    &"Missing separate debuginfo for /lib64/libm.so.6n"
    &"Try: zypper install -C "debuginfo(build-id)=24fba01931c773fd5b4688b34c4acde47ea77cb9"n"
    &"Missing separate debuginfo for /lib64/libc.so.6n"
    &"Try: zypper install -C "debuginfo(build-id)=bd1473e8e6a4c10a14731b5be4b35b4e87db2af7"n"
    *stopped,reason="solib-event",added=[library="/usr/local/lib64/libtre.so.5",library="/lib64/libm.so.6",library="/lib64/libc.so.6"],thread-id="1",stopped-threads="all",core="2"
    -break-list
    info shared
    &"info sharedn"
    No linux-vdso.so.1
    0x00007ffff7bcd060 0x00007ffff7bd86f0 Yes /usr/local/lib64/libtre.so.5
    0x00007ffff78b26a0 0x00007ffff791af08 Yes /lib64/libm.so.6
    0x00007ffff751f470 0x00007ffff764f9f0 Yes /lib64/libc.so.6
    OK
    -exec-continue
    ^running
    =breakpoint-modified,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00000000004015e7",func="main",file="simple_demo.c",fullname="/home/pc/Programming/libcrm114-20100726/simple_demo.c",line="131",times="1",original-location="main"}
    *stopped,reason="breakpoint-hit",disp="keep",bkptno="1",frame={addr="0x00000000004015e7",func="main",args=[],file="simple_demo.c",fullname="/home/pc/Programming/libcrm114-20100726/simple_demo.c",line="131"},thread-id="1",stopped-threads="all",core="2"
    -break-delete 1
    OK
    -exec-continue
    ^running
    =thread-exited,id="1",group-id="i1"
    =thread-group-exited,id="i1",exit-code="0"
    *stopped,reason="exited-normally"
    #2028
    Weird, now it works.. I didn’t change anything. Oh well, sorry about the useless thread, you can delete it.
