GCC 14 / C23 support
Sysprogs forums Forums VisualGDB GCC 14 / C23 support
  • #36264
    bflannery
    Is there a planned timeline for updating to GCC 14.X and adding support to the C_STANDARD option for C23?
    Is there a way to enable the C2X flag as an option for C_STANDARD in the current 13.X release?
    #36265
    VisualGDB is designed to work with any GCC-based toolchain that is otherwise usable (i.e. can build code without errors). You can point VisualGDB to it by selecting the import option at the bottom of the toolchain selector.
    Same for compiler flags like the C_STANDARD: VisualGDB shows a suggestion list based on the XML files in its own directory, but you can always specify a different value, as long as your toolchain supports it.
    Update: we have updated the ARM toolchain package that is automatically installed by VisualGDB to the latest release from ARM (14.2). You can install it via VisualGDB Package Manager.
    • This reply was modified 1 year, 2 months ago by support. Reason: Mentioned updated package
