Sysprogs forums › Forums › VisualGDB › Functions of class not recognized
- This topic has 10 replies, 2 voices, and was last updated 7 years, 5 months ago by
MystikReasons.
March 31, 2019 at 20:56 #24518
MystikReasons
ParticipantUnfortunately the fix for this one: https://sysprogs.com/w/forums/topic/members-of-structs-not-recognized/ has opened another problem with the IntelliSense and classes in C++.
If I declare a function inside of the private sector inside a class the IntelliSense won’t shot it in the autocomplete.
But if I declare it in the public sector it is being recognized.
You can use the same sample project from the old topic above or just create a Embedded Project with C++ support and create a class.
March 31, 2019 at 23:28 #24520support
KeymasterSorry, we would still need specific steps to reproduce it. You don’t need to attach a whole project, just the contents of the source file (s), the exact place where you trigger the code completion and what do you expect to see vs. actually see will be sufficient.
April 3, 2019 at 07:39 #24549MystikReasons
ParticipantI’ve extended the sample project with two functions, one declared in the private sector and one in the public sector.
I’ve sent the project via the support to you.
Steps to reproduce it:
- Create a function inside the class (.hpp file) one private and one public
- Change to the .cpp file and try to use the Clang IntelliSense autocomplete
You will see that only the public function is showing up
I’m using VisualGDB build 3039 with Visual Studio 2019 Preview 4.4
This reply was modified 7 years, 5 months ago by
MystikReasons.
April 3, 2019 at 07:48 #24551MystikReasons
ParticipantUpdate: This is not only working with private functions. Just tried a private struct and it’s also not showing up
April 3, 2019 at 19:36 #24557support
KeymasterThanks for sending us the repro project. We have fixed the issue in this build: VisualGDB-5.4.104.3057.msi
April 4, 2019 at 08:52 #24569MystikReasons
ParticipantIt works now. Thank you!
April 4, 2019 at 13:23 #24572MystikReasons
ParticipantThis fix unfortunately opened another problem…again ^^
If I make a pointer to this class lets say in the main.cpp (in the repro project it is LEDBlink.cpp) and try to access the public functions/structs I can select the private function “Private_Func()” and this shouldn’t work. Also I can’t see my public structs, only my public funtion.
I’m sending you the repro project again over the support.
See attached screenshot for the error
You must be logged in to view attached files.April 4, 2019 at 17:23 #24576support
KeymasterNo problem, we have fixed it in this build: VisualGDB-5.4.104.3059.msi
April 4, 2019 at 20:42 #24579MystikReasons
ParticipantIt got worse. Now the autocomplete is showing nothing (see screenshots)
You must be logged in to view attached files.April 4, 2019 at 21:27 #24582support
KeymasterThis looks correct. Based on your screenshot, there are no non-static fields or methods in the class, so code completion has nothing to show.
April 4, 2019 at 21:36 #24583MystikReasons
ParticipantYou are completely right. I’ve mixed something up in my brain. Thank you for the fast fix
