Flashing QSPI STM32
Sysprogs forums › Forums › VisualGDB › Flashing QSPI STM32
Viewing 11 posts - 1 through 11 (of 11 total)
  • #11895
    Taisen
    HI VisualGDB,
    I am trying to flash QSPI using VisualGDB, first, this tutorial is some old and not been updated. https://visualgdb.com/tutorials/arm/stm32/flash/
    The tutorial is using this code to fille the OpenOCD scripts:
    -c “flash bank qspi plugin 0x90000000 0 0 0 0 C:/projects/QSPIDriver/Debug/QSPIDriver.elf”
    However, the OpenODC documentation told use to do like this: http://openocd.org/doc/html/Flash-Commands.html#flashdriverlist
    flash bank $_FLASHNAME stmsmi 0xf8000000 0 0 0 $_TARGETNAME
    First, in your code,  where is “qspi” defined?? If I use $_FLASHNAME, the system will say the Error: flash bank name ‘stm32f4x.flash’ already exists
    If I change to qspi, ok, no error but nothing could be started…
    The OpenODC document said Config Command: flash bank name driver base size chip_width bus_width target [driver_options]
    In your tutorial, you are using four 0, but in the documentation, it only using three 0 after the address, which one is right?
    The last, even if change all the code and make no error, but system still say: Failed to connecto to the debugstub, please check the gdbserver output for more detail
    “flash bank qspi plugin stmsmi 0 0 0 C:/projects/QSPIDriver/Debug/QSPIDriver.elf”
    Here are the log of the system:
    VisualGDB is licensed to Taisen Zhuang
    C:\SysGCC\arm-eabi\bin\arm-eabi-gdb.exe –interpreter mi C:\VisualgdbProjects\QSPIDriver\QSPIDriver/Debug/QSPIDriver.elf
    -gdb-version
    =thread-group-added,id=”i1″
    GNU gdb (GDB) 7.12
    Copyright (C) 2016 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html&gt;
    This GDB was configured as “–host=i686-pc-mingw32 –target=arm-eabi”.
    <http://www.gnu.org/software/gdb/bugs/&gt;.
    <http://www.gnu.org/software/gdb/documentation/&gt;.
    For help, type “help”.
    Reading symbols from C:\VisualgdbProjects\QSPIDriver\QSPIDriver/Debug/QSPIDriver.elf…
    done.
    GNU gdb (GDB) 7.12
    OK
    -list-features
    No symbol “disassembly” in current context.
    -gdb-set print demangle off
    OK
    -break-insert -f main
    ^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0x200015aa”,func=”main()”,file=”LEDBlink.cpp”,fullname=”C:\\VisualgdbProjects\\QSPIDriver\\QSPIDriver\\LEDBlink.cpp”,line=”20″,thread-groups=[“i1″],times=”0″,original-location=”main”}
    set remotetimeout 60
    &”set remotetimeout 60\n”
    =cmd-param-changed,param=”remotetimeout”,value=”60″
    OK
    target remote :5282
    &”target remote :5282\n”
    Remote debugging using :5282
    &”Remote connection closed\n”
    qt: Failed to connect to the debug stub
    at v.o(String a, rg b)
    at v.p2(IEnumerable`1 a, Boolean b)
    at v.i1_2(DebugCustomizationSettings a)
    at vj.b2()
    at VisualGDB.GDBDebugEngine.d1(rw b, a a)
    Also, I find some post by other user, https://sysprogs.com/w/forums/topic/how-to-import-a-makefile-project/#post-11894
    What I should do about this??
    • This topic was modified 9 years, 2 months ago by Taisen.
    #11898
    The “flash bank name ‘stm32f4x.flash’ already exists” error means that the FLASH name you specify is already used by the default FLASH memory bank. Simply change $_FLASHNAME to any arbitrary name (e.g. qspi). The bank name does not refer to a specific driver, instead it defines a unique name for the newly created bank.
    The “Failed to connect to the debug stub” message means that GDB could not connect to OpenOCD (most likely because OpenOCD exited with an error). Please examine the OpenOCD window (or the GDBServer log in the VisualGDB error detail window) for details.
    #11912
    Taisen
    Hi Thanks for the feedback, but I am following your instruction in this page, https://visualgdb.com/tutorials/arm/memories/ and get no success.
    First, where is the “plugin” device name come from? If I use “plugin” system will report error, if I use “stm32f2x” as device driver, I will get no error. But still, nothing write into the QSPI.
    -c “flash bank qspi stm32f2x 0x90000000 0 0 0 0 C:/VisualgdbProjects/QSPIDriver/QSPIDriver/Debug/QSPIDriver-QUADSPI.bin”  -c “init” -c “reset init”
    I tried use the github file to repeat your results, https://visualgdb.com/tutorials/arm/stm32/flash/
    But when I do the “TestFLASHProgramming(0x90000000, 0);” the system will not write anything into QSPI, could you try to follow your guild and repeat it again? I already tried several time with no success…
    #11913
    Taisen
    <h3>Here I attached the error when I use “plugin” as driver name</h3>
    #11915
    Taisen
    I am following your guild step by step for two samples, only one different is here, the “plugin”, in my case, I always report error, so, I have to use “stm32f2x” as driver name
    • This reply was modified 9 years, 2 months ago by Taisen.
    #11918
    Taisen
    Here is the steps I am following you guild, but still nothing write into the QSPI
    As you could see, I copyed the QSPIRoutines.cpp file
    I added the script as reference told
    add the external memory
    Here is finial results, as you could see, the memory still nothing and the address is 0x90000000.
    #11925
    Taisen
    I figured out some error in my code, I am using stm32F769I-Disco, but the board support for QSPI by VisualGDB is STM32F7469G, which is 128M not 512M, BUT, still flash nothing on the QSPI.
    #11939
    Looks like there is a confusion about the “stm32f2x” vs “plugin” driver. The “stm32f3x” driver is a built-in OpenOCD driver that is only capable of programming the regular on-chip FLASH memory. Hence if you specify “stm32f2x” in your command, OpenOCD will try to use that driver and fail.
    The “plugin” driver is a special driver only supported by our OpenOCD fork that will load your ELF file (that must include certain symbols) into the device and call functions from it to program the memory. The error message in one of your previous posts actually contained a clipped line “Invalid FLASH plugin”. Please switch back to using “plugin”, get that message to appear and check the rest of that message. It should provide a clue on why the ELF plugin could not be loaded and resolve the errors mentioned there in order to get it working.
    #11967
    Taisen
    Hi VisualGDB Team, Yes, after I change that back to plugin, the system return this messages:
    Here is my setup for the flashing command.
    #11972
    Taisen
    Hi VisualGDB Team, I am little confused about this two tutorials: https://visualgdb.com/tutorials/arm/stm32/flash/ and https://visualgdb.com/tutorials/arm/memories/
    I am following  https://visualgdb.com/tutorials/arm/stm32/flash/ this driver tutorial, and at this point, at the very end of the tutorial, it back to another External Memory tutorial… Should I add all the drivers into the External Memory project, which means I should copy all the FLASHPluginCommon.cpp file into the External Memory Tutorial to make the
    -c “flash bank qspi plugin 0x90000000 0 0 0 0 $(RemoteSourceDir)/$(ConfigurationName)/$(TargetFileName)” -c “init” -c “reset init” code work???
    In the flash Driver tutorial, I could using Quick Setup OpenOCD to flash run TestFLASHProgramming(0x90000000, 0); (NOT the -c “flash bank qspi plugin 0x90000000 0 0 0 0 $(RemoteSourceDir)/$(ConfigurationName)/$(TargetFileName)” -c “init” -c “reset init”), I could flash the RAM with NO error, but when I using Memory Tool to look into the 0x90000000, there are all zero.
    If I using the STM32 ST-Link Utility to check the memory, yes, I has been changed, why? Why the Memory in the VisualGDB Does NOT work?
    Could you make this two tutorial clear? Do I need to copy all the FlashPluginCommon.cpp to the External Memory Tutorial??
    #12014
    OK, thanks, the issue was caused by the FLASH initialization code timing out. We have fixed this in an update to our OpenOCD package and also updated the flash_drivers examples to specify the timeout values instead of hardcoding them in OpenOCD.
