Sysprogs forums › Forums › VisualGDB › First use of VisualGDB….
- This topic has 2 replies, 2 voices, and was last updated 4 years, 6 months ago by
Mr Fox.
March 18, 2022 at 04:19 #32425
Mr Fox
ParticipantHi all. I haven’t used C++ for 20 years so please bear with me. Though I had 12 years commercial C++ before that and now have 20 years commercial C# experience.
Anyway. I find I need to build a small program for RPI and I loathe Python, so I thought, how hard can it be, right? 🙂
I am using VS2022 community on a Win10 platform. RPI has latest Debian-ish Raspberry OS.
I followed the instructions at
https://visualgdb.com/tutorials/raspberry/crosscompiler/
and got everything up and running:
Linux project wizard, Application, MSBuild, Raspberry Pi cross toolchain, linked OK to the RPI via SSH
except when the project template wizard finished I got an exception:
VisualGDB version: 5.6.104.4534
------------------ System.ArgumentException ------------------
System.ArgumentException: Invalid ruleset name: ConfigurationGeneral
at g22.SetCustomPropertyValue(String a, String b, String c)
at xx.k(cw1 a, IProjectEditContext c, o b, nz1 d, t f, Boolean g, z[] e)
at uk3.i(LinuxWizardState d, cw1 a, String b, String e, nz1 c)
at uk3.DoRunWizardOrThrowException(nz1 a, String c, String b)
at r22`1.Execute(Object e, IntPtr a, Object[]& c, Object[]& b, wizardResult& d)</code>
<code>trace=[g22.SetCustomPropertyValue:41, xx.k:404, uk3.i:523, uk3.DoRunWizardOrThrowException:642, r22`1.Execute:210]And building I get
Error MSB4019 The imported project "C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v160\Microsoft.cpp.targets" was not found. Confirm that the expression in the Import declaration "C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v160\\Microsoft.cpp.targets" is correct, and that the file exists on disk. LinuxProject2 C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.Cpp.ToolsetLocation.targets 21When I look at the HelloWorld example code (I have Resharper C++ installed) I see that
#include <iostream>
isn’t found.The VisualGDB blurb said it was clever and would sort out all the includes…. so I’m worried.
Conversely it’s entirely possible I’ve just not installed something right.Thoughts? Many thanks.
March 18, 2022 at 08:41 #32431support
It looks like your VisualGDB installation is corrupt (missing MSBuild platform), or you have edited the project in a way that breaks MSBuild integration. In order to resolve it, please try:
- Uninstalling VisualGDB completely and deleting its directory
- Installing it again
- Following the tutorial to the letter to create a new project from scratch.
If it still doesn’t work, provide complete and detailed steps to reproduce the issue as described below:
- The steps should begin with launching Visual Studio. They should include every step necessary to create the project from scratch and reproduce the issue.
March 18, 2022 at 13:32 #32436Mr Fox
ParticipantSolution: Install VS2022 C++ (I just had C#) BEFORE installing VisualGDB…. 🙂
